Question about Optimus DV-3040 Flash Media Camcorder
Sanyo xacti waterproof video camera
The screen does not turn on
Viewer screen is white, i can record and playback but the screen is white, its an xacti waterproof 6mg model
hi Usually white screen problem is defective lcd unit. your local repair shop would charge $45 to 75 depend on what they want to charge. Thanks and best regard!
May 24, 2011 | Sanyo Xacti VPC-T700 Digital Camera
Do u have an english manual of sanyo xacti ca9?
You can download the manual from the manufacturer's web site at
http://us.sanyo.com/dynamic/extranet/servicers/VPC-CA9_OM_English.pdf
Feb 05, 2011 | Sanyo Xacti VPC-CA 9 Flash Media Camcorder
My sanyo vpc-cg20 monitor shows updide down how do i fix it
http://us.sanyo.com/Cameras-Camcorders-Previous-Models/VPC-E1-Waterproof-Digital-Video-and-6MP-Photos
The above is a description.
I checked the online FAQ's and support, but didn't find an upside down image on monitor problem.
So, I think your best bet for your waterproof camera is to have it serviced by Sanyo.com.
http://us.sanyo.com/Customer-Support-Service-Center-Locator
Jul 24, 2010 | Sanyo Xacti VPC-E1 Camcorder
Sanyo xacti digital camcorder screen not working when opened out
Hi!
It's most likely a damaged LCD cable which goes through the hinge - happens to many camcorders. You will have to contact your local Sanyo service center. I replace these cables for Sony camcorders every day.
Sorry for the bad news, but hope this helps.
Tom
Sep 27, 2009 | Sanyo Xacti E1 Waterproof Camcorder
Black screen when camera is turned on
Sanyo will replace it for $50 if you mail it to them. Just contact them for the address and slip.
This is common. The parts are hard to find. Your best bet would be ebay
COPY AND PASTE THIS LINK IN YOUR ADDRESS BAR;
cgi.ebay.com/SANYO-XACTI-VPC-E6-LCD-SCREEN-DISPLAY-REPLACEMENT
Sep 10, 2009 | Sanyo Xacti E6 Digital Camera
Lcd on Video camera not working
take the LCD apart & look up the numbers on the back of it, order the part from were ever you find it form google & put the new one in urself when it arives, this will safe you @ least 100$ on someone else doing the same thing
Mar 17, 2009 | Sanyo Xacti VCP-HD2 Camcorder
Manual
Go to http;//audio.manualsonline.com good luck
Jun 30, 2008 | Video Cameras
Sanyo XACTI HD1 Camera-No Pictures / Videos captured.
I have intermittent problems of this type too. Occasionally I get a blank screen in the display mode.
Does the red light on the back of your camera flash while the screen is dark? Mine does.
It is beginning to bug me a lot. It may be because I got my camera wet in the past (and hence I have broken my camera), but I doubt that would result in a partial failure.
I think that the Xacti HD1/HD2 has issues a bit like a blue screen of death on an old Windows computer when faced with storage problems.
I.e. it works but crashes sometimes when it cannot store to its storage medium.
These things work for me
1) Turning the power on and off via the button underneath the screen.
2) Removing and re-inserting the SD card.
3) Turning the power on and off by removing the battery.
4) Using a different (and faster?) SD card.
I am still using my HD2, but I am finding that I must attempt solutions 1-3 about once a day.
It could be because the card I have been using recently is not fast enough. The HD2 accepts both SD and SDHC cards. My SDHC card (which is newer) seems to result in fewer problems, either because the SDHC format is more suited to the Xacti HD2 or becaues the SDHC card I have is faster that then SD card I have. I suspect problems with the speed of the card. I am using cheap SD cards.
Dec 07, 2007 | Sanyo Xacti HD1 Memory Card Camcorder
Optimus DV-3040 Flash Media Camcorder Logo
23 people viewed this question
Top Optimus Video Cameras Experts
Are you an Optimus Video Camera Expert? Answer questions, earn points and help others
