Question about Aliph Jawbone Jambox - Black Diamond Portable Speakers W/ Bluetooth Unopened
Is a replacement usb, power switch and aux port circut board available from jawbone jambox
Aux port and power switch broken
Connect to my phone - apple
Turn bluetooth and look for your speaker probly jawbone.
Mar 24, 2015 | Jawbone Mini JAMBOX Wireless Speaker
Where is the AUX connection on the radio
There is no port. There should be a ten wire bundle (5 pair) coming out of the back (next to the power port). One pair of wires should be labeled aux in.
Jan 31, 2015 | Panasonic CQ-DF602U CD Player
Can I connect my hmdx rave to my next book?
Yes, you'll need a 3.5 mm audio cable (PC audio) with M/M ends. Connect the cable between the headphone jack of the Next Book and the Aux Input of the Rave speaker. The Aux Input jack on the speaker is between the charging port and the On/Off switch. The headphone jack is between the power button and the DC Power Input port on some Next Book models; you should check your unit's documentation for the exact location. Only the volume controls on the Rave speaker will work. You'll need to select tracks and press Play/Pause on the Next Book.
I hope this helps.
Sep 29, 2014 | Tablets & eReaders
Jambox
The same thing it's happened when my jam box won't turn off because the Power Button has sunken in!? Someone help!
Aug 28, 2014 | Jawbone Big Jambox Portable Bluetooth...
Aux input not working
Unfortunately the whole head unit needs to be replaced if the actual port is broken,but before you spend all of that money buying and installing a new head unit,try to replace the cable that you are using.if it still does it after the new cable then try to get some electric contact cleaner spray from the auto parts store CRC makes a good cleaner spray.Spray it into the aux port on the head unit and see if that works.If that does not work then replace the whole head unit
Apr 01, 2014 | 2010 Chevrolet Cobalt
Aliph Jawbone Jambox - Black Diamond Portable Speakers W/ Bluetooth Unopened Logo
19 people viewed this question
Top Aliph Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Aliph Radio Communication Expert? Answer questions, earn points and help others
