Teac cd x10i parts catalogue
I lost the cable that connect the unit to the sub-woofer. what do I need to replace it?
3 Suggested Answers
SOURCE: teac cd-x10i
  1. press the standby/on switch off
  2. Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. press the right and left arrows to select. press TIME SET again.
  3. the hour value blinks use the right and left arrows to select the current hour. press TIME SET gain.
  4. The minute value blinks. using the right and left arrows select minutes.
  5. press TIME SET again and the clock starts.
Posted on Jan 04, 2008
SOURCE: missing a cable from main unit to sub woofer.
Bought the wafr stereo system, came without the 9 pin male to 9 pin male subwoofer cable. Called the Brookstone outlet I bought it at and they are mailing me one. Cable is actually power and audio combined, specialty cable, you probably can't find one in any standard outlet
Posted on Nov 29, 2011
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
I ended up with one piece of a Teac model CD-X8 MIcro Hi Fi System. you can see what the whole system looks like at http://www.amazon.com/Remanufactured-CD-X8-Wall-Mountable-System-Subwoofer/dp/B000B65GV6...
Yes - you have the sub-woofer. It is a powered sub-woofer with a built in amplifier for both itself and a pair of small satellite speakers. Frankly, given the low cost of the whole system it may not be worth selling on ebay due to the high shipping costs of such an item, but I imagine you could get $30 for it or so on local craigslist or something, assuming you have no use for a sub-woofer...
May 05, 2011 | Audio Players & Recorders
Wgy does my cd player only have one sub outlet rca?
Some dvd head units only provide a single mono RCA output for sub woofers. Not to worry. Buy a Y-Splitter RCA cable (1 Male to 2 Female) Now connect your normal RCA cable to that as you would do with any other unit.
dreamsystems
Feb 16, 2011 | Jensen Car Audio & Video
I have jvc car audio model # kd-g335 how to connect my sub woofer?
You can not connect the subwoofer directly to your head unit. You need an amplifier installed to play the sub woofer. Asuming that there is an amplifier installed then: If your head unit has an RCA output on the rear, connect that to the LINE IN of your amplifier. Also there should be a Blue&White cable at the rear of the head unit.(amplifier remote) That should be connected the the remote terminal on the amplifier. (this will turn the amp on and off when the head unit turns on or off) Hope this helps. dreamsystems
Feb 08, 2011 | JVC KD-G340 Car CD/ MP3 Player
My teac micro hi-fi system CD-X10i doesnt work
many units have a fuse inside the back cover near where the power cable comes in. be careful to replace it with the same size fuse as the problem that blew the fuse might still be there and could potentially cause a fire.
I have the same unit and i am looking for help because the cd will not run (wont spin the cd), but the door works. also the FM reception sucks.
Larry
Jun 15, 2009 | Teac CD-X10i Docking Station for Apple...
Teac AG D8900 II sub woofer not working
click on the blue "teac sub woofer" link top of page, solution is in my response to another with same problem-that is at least 3 of us with this now.
JS
Dec 26, 2008 | Teac AG-D8900 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
System is lit with no display does not turn on
your set needs to be repaired have a tech look at your set, the power supply is defected along with the audio output.good luck
Jun 03, 2007 | Teac CD-X8 CD Shelf System
Setting clock
call(1-323-726-0303 ext.617) or go to this site for contact details http://www.teac.com/consumer_electronics/CustomerService.html or you can e-mail to parts@teac.com and request a manual, or this link will let you get the manual online http://www.service-manual.net/ashop/catalogue.php?exp=&cat=237 only slight problem is this download will cost you $11.99, should be free from teac direct. Hope this helps :)
Feb 28, 2007 | Teac CD-X8 CD Shelf System
50 people viewed this question
 Grubhead
Grubhead
