Question about Chevrolet 1995 Chevrolet Blazer S10/jimmy S15 Radio
Where is the computer located on a 95 chevy s10 blazer
SOURCE: can't find the oil filter
You probably have a canister filter which is located under the hood. You have to screw off the top of a canister and the oil filter looks like a small cylinder-like paper filter. Did you check your owners manual?
Posted on Aug 26, 2008
jimbopickens
  • 56 Answers
SOURCE: 98 chevy s10 blazer turn signal
Unplug the turn signal relay from the fuse box and start you engine. Does it still make that noise?
If yes... Put the relay back in, that is not the problem.
If No...Then the relay could be bad, replace it!
PLEASE RATE THIS SOLUTION! Thank You Very Much!
Posted on Nov 25, 2008
  • 82 Answers
SOURCE: 1999 Chevy S10 Blazer 4x4. Replacing rear pad's,& Bleeding Breaks
have one person in the blazer pumping the brake pedal and then hold to the floor, crack the bleeder then tighten, release pedal, repeat till all air is out one side at a time, if this does not work then your ABS unit is bad witch if u follow your lines from your master cylinder u will find a black box with a motor on it, or the master cylinder itself is bad, it also can cause u to have no pedal, replace the master cylinder first, most likely cheaper.
Posted on Mar 11, 2009
  • 495 Answers
SOURCE: need the fuse diagran fo chevy blazer s10 4wd 1991
go to autozone.com, enter your vehicle specs, and follow the prompts for the repair section, then to electrical diagrams..........and its FREE!
Posted on Jul 27, 2009
BCAS1298
  • 3092 Answers
SOURCE: trying to locate the ignition module for chevy
Ignition module sits in the ignition distributor, remove distributor cap, there will be two elec. harness plugs, the one with two wire's is for the pick up coil, the other one is for the ignition module, just unscrew module out of distributor and install new one.
Posted on Sep 23, 2010
I have a 2003 Chevy blazer with a 4.3 vortec motor it has a small leaking head gasket how long can I drive it until I have the money to fix it.
Troubleshooting a Blown Head Gasket (GM 4.3L, 5.0L, 5.7L)
troubleshootmyvehicle.com > GM > 4.3L, 5.0L, 5.7L
Mar 28, 2011 - There are so many ways to test for a blown head gasket on your 4.3L, 5.0L, 5.7L GM van (or mini-van, pick up, SUV) that it can get confusing.
Chevy Blazer Coolant Leak (Intake Manifold) - YouTube
? 4:33
https://www.youtube.com/watch?v=SC4VXdt5wiE
Oct 9, 2013 - Uploaded by eyetotheworld
I have localized a coolant leak on my 2003 Chevy Blazer to thegasket of the intake ... Turns out that this is common among this particular engine both in the v6 & v8 sizes. ... The guy has been generous to detail his projects. ... 98 S10 Vortec V6 4.3 IntakeGasket Replacement Part 1 of 5 - Duration: 18:17. by ...
Chevy 4.3l v6 oil leak issue 2001 Xtreme Blazer - YouTube
? 6:11
https://www.youtube.com/watch?v=Y8Ogd5voIYs
Nov 12, 2011 - Uploaded by smiatacz
This darn little engine just keeps going. ... I have a 2003 chevy blazer and the oil cooler line from the oil filter to ... I have a 95 Chevy s10 v6 vortec 2wd that is slightly dripping oil out of agasket ... I'm having same problem 2001 Chevy Blazer 4x4 (not xtreme) not sure if those same bolts are missing on mine.
Dec 28, 2015 | Cars & Trucks
95 chevy blazer won't accelerate, has rough idle and back fires
when was the last tune up done on it? have you checked the spark plugs and firing order to make sure it is correct?
Apr 21, 2014 | 1995 Chevrolet Blazer
My chevy s10 pickup 2.2l sputters amd backfires even blew out muffler i have tried everything i can think of whats wrong
The timing chain and gears are probably worn causing late valve timing. This will cause backfires, and flames out the intake. I'm guessing this is a high mileage engine.
Jan 22, 2014 | Metra Chevy S10 t10 Pickup, Gmc Sonoma...
95 CHEVY S10 PICK UP V6 4.3.TEMP GAUGE WONT WORK
The temperature gauge sensor for a 1995 Chevy Lumina is located in the sending unit. --------------------------------------------------------------------------------
PSA BSI tool
Mar 20, 2013 | 1994 Chevrolet S-10 Blazer
Cant locate my fuel injector in my 95 chevy blazer
Your '95 blazer does not have fuel injectors as such. Fuel delivery is accomplished by way of a " throttlebody" injection system. This unit is mistaken for a carbuerator but is systematically controlled through several electrical connections by the on board computer.
Apr 10, 2011 | 1995 Chevrolet Blazer
Can i get a t-harness for a 1997 s10 blazer
1997 blazer needs GM-1 harness
S10 blazer were only made until 1994 I think
Jan 15, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Chevrolet 1995 Chevrolet Blazer S10/jimmy S15 Radio Logo
27 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
CrisO
Lawrence Oravetz
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
