Question about Sanyo Televison & Video
When I turn my VCR on "RF-03" comes on the screen and no matter what button I push it won't work. What's the problem?
Sanyo VWM-390
centralhigh
  • 260 Answers
SOURCE: remote control problems
I would love to say we can help, but the truth is, you remote needs to be replaced. One of the advantages to have the remote is that you wear out the remote, not the controls on the tv. And replacing a remote is much cheaper. You have done all you can to save this remote. You will need to replace it.
CH
Posted on Jul 30, 2008
57 varieties
  • 1653 Answers
SOURCE: sanyo vcr player vwm 900, tape won't COME OUT.
This needs a little bit of care but essentially you will need to unplug the power from the VCR then do the following:
Remove the top cover
Then with the front of the VCR facing you look to see if any of the tape is wound around a large metallic silver drum, that is tilted upward and is not flat, at the rear of the tape casing. If so then it means that it has wound around the drum and you will need to retrieve the tape to allow the eject mechanism to work. Do not touch the shiny polished part of the drum. To get the tape in usually means that you have to locate a plastic or metal cog wheel, usually on the right side of the VCR that you can turn with your finger. This makes the VCR motor move. Also there is one that works the tape eject mechanism. If you can find the one to wind in the tape before working on the one for the tape eject than you stand a chance of rescuing the tape, if not then it will get some damage. Don’t worry about turning the cog wheels with your finger as you can do very little harm to the VCR with no tools involved and no power on. Moving the cogs this way will only cause very small movements with the tape motor and eject so you will need to be a little patient and you will soon see what is happening. Once remove run a cleaning tape through the VCR before you use it again. With the limited space available her it is difficult to give you much more info.
Posted on Sep 11, 2009
Grubhead
  • 5190 Answers
SOURCE: what's the universal remote code for the sanyo
Try these: 1022, 1045, 1047, 1070, 1131, 1172, 1192, 1203.
Posted on Oct 14, 2009
Grubhead
  • 5190 Answers
SOURCE: Video heads of Sanyo VWM-800 4 head vcr need cleaning.
Take the top off and spray the main head with Servisol Video 40. (image below) Also the tracking and audio heads.
Wait for it to dry before putting a tape in. In the future use only this it is much better and cheaper than cleaning tapes.
Posted on Mar 10, 2010
SOURCE: my sanyo vcr model vwm 690 won t run auto setup when connected to
the sanyo 690 is the best vcr out I have had mine for 10-12 yrs!
just make sure you are in the vcr mode and not tv or cable mode it will do everthing for you!!!!!! columbo
Posted on Jan 25, 2011
Sanyo vwm390 vcr
That might be the TV output channel. I found these instructions in a Sanyo manual:
How to set the DVD+VCR's RF output channel 1. Set the TV to the VCR channel (3 or 4) depending upon the selected channel. 2. When the DVD+VCR is turned off, press and hold CHANNEL (V/v) on the front panel for more than five seconds. It will turn itself on and "RF03" or "RF04" appears in the dis-play window. 3. Press CHANNEL (V/v) on the front panel or CH/TRK(v/V) on the remote control to change the RF output channel (CH 03 or CH 04). 4. Turn off the DVD+VCR.
It might solve the problem!
Jan 01, 2014 | Televison & Video
Need a owners manual for a Sanyo vcr vwm 800
Here is the manual for the next model up. It should be similar enough to fix your problem. I hope this helps. http://www.retrevo.com/support/Sanyo-VWM-900-VCRs-manual/id/311ag907/t/2/
Mar 15, 2011 | Sanyo VWM-800 VHS VCR
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
How do I set the timer to record on my Sanyo VWM-410?
Well I think that theres a record button on the vcr that you press and it does recording and you can press the pause button for to give it a rest then.
Oct 02, 2009 | Sanyo VWM-700 VCR
My sanyo vcr model vwm 690 won t run auto setup when connected to
Mar 22, 2009 | Sanyo Televison & Video
VCR not working
The heads are dirty or misalligned. Try running a cleaning tape through it. If that fails, it needs to be serviced.
Sep 01, 2008 | Sanyo VWM-800 VHS VCR
Will only display on ch 3
You will need to take the original remoter and go into the menu, find the channel set up and reprogram the VCR for the channels, as when you lost power the channels also went out because of the memory chips need the power to hold the data.
Apr 29, 2007 | Sanyo VWM-950 VHS VCR
Can't get picture to display on ch 4
there is a switch at the back that you can to channel 4 or 3 good luck
Apr 17, 2007 | Sanyo VWM-950 VHS VCR
Televison & Video Logo
121 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
