Question about Ovens
Sears MO 5500air compressor instruction manual
My lamona single oven has stopped working but previously was fine. What can I do please ?
Hello Hayley Wager, fix it.
None of your appliance nomenclature came through with your question...
First avenue to restoration ...
Check your power sources... cycle the breakers
(turn off & back on).
Check your oven settings to make sure they are NORMAL...
No delay or TIMED cooking programs have been invoked.
Clear all settings...
failing all the above... get out your manual and read the RESET instructions...
Failing that read the TROUBLE SECTION...
New manuals can USUALLY by obtained On-Line by
inputting (for a search)
owners+manual+(your make)+(your model)...
likewise: parts/spares... +(your make)+(your model)...
While good information can be had at SEARs my favorite (USA) is
appliancepartspros.com for prices...
Although SEARs is beginning to become competitive... always get three estimates.
My first suggestion.. when buying parts for an oven... on a guess
is the thermostat
You can get a cheap volt-ohm meter and test your heating element...
Not knowing the make and model... I can only say the bake & broil elements are usually different... one work... but not the other means good power & switching (usually the element itself).
Happy hunting...
Sears
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
May 02, 2016 | Ovens
Need a manual
J Evans google search your make,model #,manual. or Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://outlet.whirlpool.com/digitalassets/CWE5800ACS/Use%20and%20Care_EN.pdf
oven manual Google Search
Owner Manual Installation Instructions
http://www.sears.ca/content/free-standing-stoves
Apr 18, 2016 | Ovens
How do I override the sabbath feature on the elite dual fuel range?
since each model and each manufacturer operating procedures are different, it is best to read the instruction direct from your owners operating instruction booklet that came with the unit. If you don't have one, you can usually order one from sears parts direct for your specific model.
Sep 30, 2014 | Kenmore Elite Stainless Steel 40" Dual...
Owner manual for Sears stove model c880 6496 182
you must have the serial number there Sears has not record of that model number.
Jun 15, 2014 | Stoves Ovens
Require instruction manual for Thermatronic II double oven.
Here is a contact number for sears. (800) 252-1698 Maybe they can help you find one. Good luck
Oct 31, 2013 | Thermador C302U Electric Double Oven
We just bought a Kenmore Elite Oven, model 4809, at a Sears Outlet Store. I've looked all over your website and cannot find dimensions or installation instructions. I looked at the online manual for the...
I just purchased the same model and have been searching on-line for the exact same information. Not sure if you still need it but the Sears Outlet website lists the opening dimensions for the Kenmore Elite Oven 4809 as Width 28-1/2 in. min., 29 in. max. Depth 23-1/2 in. Height 29-1/16 in.
May 01, 2011 | Kenmore Ovens
Blodgett mo # 981 will not start all the time
http://www.blodgett.com/Literature/Manuals/Deck/900-man.pdf
Go to this site for an owners manual.
Please be alittle more specific.. Are you saying that the burners do not light? Is there a pilot?
Jul 30, 2009 | Blodgett Ovens
Kenmore Stove Model 362.7331890
You should be able to get online manuals at www3.sears.com
Nov 16, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
