Question about Eureka Boss SuperLite Bagless Upright Vacuum, 405AVacuum
Want maintance on this vacuum
Need to know about cleaning filters
I want to know WHY my HEPA filter and cover blow off my unit with force each time I turn the unit on and start sweeping...Help?
Vacuum cleaners actually blow air through the filtration system. Over time particles will block the pores in the filter which doesn't allow enough air to pass through it and pressure will build up behind the filter and has to go 'somewhere'. Either clean the filter or replace it, and be certain to properly reinstall the assembly before turning it on.
Jun 13, 2014 | Shark Navigator Lift-Away Professional...
How can i fix vacuum cleaner
check for blockages in all passages
May 29, 2014 | Panasonic Vacuums
I need to know if the filter in my vacuum cleaner is washable?
What I have found over time is that even if a filter is marketed as being washable it really means that the material will not be damaged by water. The key difference here is that it won't necessarily be cleaned better by washing. Electrolux sell a lot of washable filter for example but what i find is that washing only sets the dirt as mud. The problem is that the pores of a filter are incredibly small and water does not dislogde the particles. Remember that in the normal run of things the suction power of the vacuum is actually wedging dirt into the pores.
The best way to clean a filter like that is with an air compressor but it is very messy. Generally speaking a filter will be past it's best after a year or so of usage. My advice is air compress or replace but don't wash.
If you are in need of vacuum cleaner filters in Australia try vacuumspot.com.au
May 22, 2012 | Vacuums
VACCUUM SEEMS TOOST SOME OF ITS SUCTION POWER
How often have you changed the filters in the vacuum?-- and when was the last time you did it now?
Obviously emptying the dirt collecting chamber OFTEN helps the vacuum--
but then in addition, there are several filters-- are they clean?
Pull them out, tap and otherwise shake the dirt loose from them, until they are clean--
(Compressed air is great for this-- but you might not have that nearby, right?)
Do yo have another vacuum that might help you clean up the filters?
Or-- maybe it is time to replace all the filters?
Let us know how successful your efforts on the above turn out.
Mack B
Dec 28, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
I got a new filter for my Beam central vacuum. How do I replace it? Do I take off the top lid of the canister?
You would not normally need to replace the filter unless it is damaged. Access is from inside the tank itself. Remove the bucket and locate the finger loop on the existing filter. Pull toward the inside of the bucket. Replace the filer by setting in it's track and snapping tight to the wall of the vac. Unless damaged you can save and clean the old filter for reuse.
Jun 10, 2009 | Beam Industries 2900 Serenity Plus Central...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Roomba discovery on full charge power up and it will run 5 sec power button then flashes red and roomba quits. I have tried removing battery and holding power button for 30 sec then charging same result
unfortunately the batteries on the roombas can go bad and not hold a charge and need to be replaced, also you should check all the brushes and wheels on the bottom, if they are bound up it would stop the roomba from working. the two brush rollers can be removed by pushing on the two tabs just above them, try and clean any hair from them. if its real bad you should buy the maintance kit from them witch gives you both brushes and filters as well.
Sep 16, 2008 | Vacuums
How do I clean the filters
Generic problem for all Vacuums
How do I clean the
How do I clean the filters?
Comment by Avonb, posted on Apr 22, 2008 I have a Bagless twin clean, thought I was cleaning the filters but apparently not, the manual is very vague
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the Model # or Brand name, it is a good idea that you can vacuum of the filters, if you have a blower – you can blow off the dirt from the filters, some filters are washable and you can clean them by washing them and letting them dry completely before you re-install the filters. Idea? If you have an old paint brush, that is ideal to clean off HEPA filters or cartridge filters or use a blower to clean off the dirt. You need to be the best judge on how to clean the filters. You can check the company’s website for the brand name such as:
http://www.hoover.com ---- example given
Don – The Vac Man
Apr 22, 2008 | Vacuums
U5780-900 Windtunnel maintance / cleaning
http://www.hoover.com/pdfs/manuals/U5780900.pdf
Here is a link to a pdf file at hoover website.
It explains alot.
Feb 22, 2008 | Hoover U5780-900 Windtunnel Cyclonic...
Vacuums Logo
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
