Vmd conseil - Computers & Internet
Tip
How to Generate More Traffic by Using Google Translate.
When writing a Tip or Trick, you can use Google Translate to write them in additional languages besides English resulting in more customer traffic from other countries.<br /><span>Al escribir un Consejo o truco, puede utilizar Google Translate para escribir en otros idiomas adem&aacute;s de Ingl&eacute;s que resulta en m&aacute;s tr&aacute;fico de clientes de otros pa&iacute;ses.</span><span><br /></span><span>Lorsque vous r&eacute;digez un Conseil ou Trick, vous pouvez utiliser Google Translate pour les &eacute;crire dans d'autres langues que l'anglais r&eacute;sultant du trafic des clients d'autres pays.</span><span><br /></span><span>Kapag sumusulat ng isang Tip o trick, maaari mong gamitin ang Google Isalin sa isulat ang mga ito sa karagdagang mga wika bukod sa Ingles nagreresulta sa mas maraming customer ang trapiko mula sa iba pang bansa.</span> 当写一个提示或技巧,您可以使用谷歌翻译写在英语之外其他语言的其他国家更多的客户流量导致他们。
on Nov 09, 2010 | Computers & Internet
What hard drive is used in wj-hd316a
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Feb 25, 2012 | Panasonic (WJ-HD316A/500) (WJHD316A500)...
Bonjour je possede un ordinateur portable ACER ASPIRE 8930 G, je l ai passe sous windows seven Je voudrais reinstaller acer empowering technology que j avais lorsque j ai achete mon ordinateur et qu il...
Bonjour JosyAnne ,
Tu peux malheureusement faire une croix sur la version Windows 7 , Acer ne suit plus ?a sous cette version .
D?sol? ,
fanaudi .
May 09, 2011 | Computers & Internet
Montage du disque embrayage
bonjour mon ami? from uk my french?not too good? but do i understand? that you have santa fe 2 litro ? and you wish to know how to repair /replace the clutch assembly ?? OR? is the request regarding brake discs ?? can you D I Y yes! sorry if i not correct on your request however will assist you if you if possible? no problem i do have some spanish vocabulary translation but will have to learn more fracais! in the future no?
Nov 03, 2008 | 2004 Hyundai Santa Fe
AUDI A4 AUTO
In the gearbox sump is 2 plugs. one small to drain the oil and a big on that fits a 17 socket l-key .start engine in neutral ,turn out the :17" nut and fill with pump until oil overfills. I dit mine this way and got the advice from a good geeerbox rebuilder in Pretoria. NOW HELP ME AND TAKE A PHOTO OF YOUR SPEEDO PIPES AND E MAIL TO ME I CHANGED THE PIPES AND MIXED THEM UP AND NOBODY HAVE OR WANT TO SHARE THE INFO PLSE vmd.bakker@vodamail.co.za
Jul 11, 2008 | 1998 Audi A4
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
