Question about Brother Sewing Machines
Embroidery/sewing machine carriage won't move
Machine makes a loud noise and carriage starts to move then stops
  • 6 Answers
SOURCE: Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
Michaelle
  • 65 Answers
SOURCE: Baby lock Ellegante 2 embroidery machine
try and look here
http://www.babylock.com/embroidery/ellegante/
there is a help section
Posted on Jan 25, 2009
SOURCE: The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Warning - undertake this fix at your own risk as it will probably invalidate the warranty.
The problem is a bad connection inside the embroidery unit - there is a small plug that joins four sets of wires that comes loose.
1) disconnect the embroidery unit
2) Turn the unit over and remove the posidrive (crosshead) recessed screws on the bottom. ONLY remove the recessed screws NOT the ones holding the catch to hold embroidery unit to machine. ALSO DO NOT remove the one screw that is different (it has different head that allows a flat screwdriver as well as a posidrive)
3) Carefull turn unit back over
4) With the enbroidery unit facing you there is a screw facing you in the white cover of the hoop holder. Remove this screw and carefully remove the plastic cover.
5) On the underside of the hoop holder nearest you there are two black screws that are undone with an allen key. Remove these (they allow the main cover to come off
6) Pop out the long plastc cover under the hoop holder (where the ting moves back and forward)
7) Pop out the section of cover behind this that is now loose.
8) Carefully tease off the main cover. IT will come with patience and by moving the embroidery arm back and fortht to give space. DONT FORCE IT.
9) You will see the rails running left to right that the hoop holder moves on. Under these you should see four wires, that are joined to four other wires by a connector.
10) Wobble the connector to get them to connect again
11) Connect the embroidery unit to the machine and switch on.
12) If the carriage goes to the start position you have restored the connection. Secure with insulation tape
13) If not switch off, wobble, switch on unitl it works
14) Disconnect and replace covers.
Good luck. This sorted out our machine that just moved the carriage the wrong way and flashed red 88
Posted on Aug 27, 2009
SOURCE: I have a Brother innovis 4000d sewing and embroidery machine. The embroidery pattern l am trying to sew has worked really well in the past, but now when it starts to sew it is not picking up the botto
try changing the needle
clean under the needle plate & in the bobbin area for loose threads or lint
rethread the machine top & bobbin
Posted on Apr 27, 2012
Testimonial: "Thanks so much for the help :)"
  • 12 Answers
SOURCE: Embroidery machine is making grinding noise and carriage doesn't move. Then, screen says malfuntion, turn machine off.
Just because the hoop holder has been moved during transportation. Shut down the machine, manually bring hoop holder in central position in both X and Y, it will restart.
Posted on Jul 07, 2012
My xl400 singer embroidery carriage has stopped working. Will not move at all when machine is turned on. Also keep getting msg error about hoop size but no hoop attached.
The switch for "sew" or "embroidery" must first be in the "embroidery" position.
Make sure the connections are very firmly pushed in.
If it still isn't functional it may require some small motors to be replaced. The motors are what makes the hoop move.
Sep 28, 2016 | Singer Futura Xl-400 All-In-One Sewing And...
Where do you add oil to the simplicity embroidery machine?
In the instruction manual it should show you where you need to put the oil. What sort of noise is it making as there may be a different problem such as stuff caught in the bobbin race
May 16, 2014 | Simplicity Quilter's Classic SW240...
Board
Close your futura file & exit, switch off your futura machine. Disconnect the embroidery unit from the machine,move the hoop carriage a bit to the left then to the right & it should be able to move. Connect back embroidery unit to your futura machine,ensuring the connecting point click properly. Re thread the machine & ensure needle is fully up position. Now you switch on the machine, you will see hoop carriage moving and stop at its zero point. If that is OK and the earlier led blinking gone, you should be able to operate the futura embroidery program again.
Jul 18, 2013 | Singer CE-200 Quantum Futura Computerized...
Apr 20, 2012 | Brother PE770 Computerized Sewing Machine
I just purchased this used. The embroidery tray
You will need to take the machine in to a Brother dealer to have it looked at.
Mar 04, 2010 | Brother ULT2001
The embroidery arm is not working properly. When i try to use the embroidery feature, the arm starts in the wrong area and the machine tries to put the needle through the embroidery hoop. The arm is also...
You definitely need to take that in for service. The machine has a feature that lets it know which hoop is on the machine so is can't sew outside the hoop area, so if it does, you'll need a technician to make it right.
Oct 15, 2009 | Husqvarna Designer I
Hoop carriage is stuck
mine soes thissometimes, when you turn it on and it starts to beep, i move the presse foot lever up or down, and it should stop.
Aug 26, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Feb 27, 2009 | Singer CE-200 Quantum Futura Computerized...
try and look here
Jan 11, 2009 | Baby Lock Ellure
DISNEY BROTHER SE-270D COMPUTER SEWING & EMBRIODERY
but is the carriage moving,? if not disconnect and try to connect again, the embroidery hoop holder usually moves to check itself, if it still does the same thing the connection that goes onto the machine is not making a proper connection, I also had this problem, with a 2100 brother , I fixed it by using a crochet hook and just tightening the connection that connects to the machine on the embroidery unit, but tread very carefully it just takes a slight move. if this fails it will have to be adjusted cost is usually $100au
Sep 10, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
163 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
