Question about Craftsman Garden
Sears 725 walk behind mower
I have a 725 model 917.9994A electric start lawn mower. The battery has been charged for three days;the plug has been changed; the fuse is good;the air filter is new, but it will not start. It turns over slowly but consistently. Any ideas?
  • 83 Answers
SOURCE: lawn mower will not hold charge with new battery
Check your battery water level if it's not a sealed battery. Some small batteries require you to fill them with both acid and water, some with water only when new.
If that is not a issue then you are most likely running on your battery alone. You need to check your charging system. Check your battery voltage when the unit has not run for at least an half an hour. Then check it when it's running. The voltage should be higher. It should be 12.5 to 14vac. Lower means your alternator is not working or a fuse is blown in your charging system. Higher means your voltage regulator went bad and the higher voltage will cook your battery in time. The voltage regulator is usually in the alternator and can not be changed without replacing the alternator. Check your parts diagram. If it lists a voltage regulator then you are in luck.
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: Cant get my lawn tractor to start
IT COULD BE IGNITION SWITCH IS BAD, I REPLACED ONE ON A CRAFTSMAN THAT DID THIS,BUT ALSO COULD BE A SAFETY SWITCH IS NOT CLOSED PREVENTING STARTER FROM OPERATING,---WITH THE IGNITION SET TO ON CROSS THE TERMINALS ON SOLENOID AND SEE IF IT STARTS THE TRACTOR RUNNING, IF IT FAILS TO RUN ITS PROBALY THE IGNITION SWITCH THEN.
Posted on Apr 10, 2009
  • 74 Answers
SOURCE: I have an RZT50 Cub Cadet Mower that only starts with jump
it sounds like the starter motor is pulling to many amps for the battery to cope with. if its a 12v system it should not pull the battery down to less than 8.5 volts on cranking if it does the starter-motor is defective you can check this with a volt meeter across the battery terminals and see what it read as you crank the engine. hope this helps
Posted on May 12, 2009
  • 86 Answers
SOURCE: Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
Posted on May 16, 2009
da420bmx
  • 4 Answers
SOURCE: 19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
Posted on May 19, 2009
725 Series Electric Start Rotary Lawn Mower 22" Multi-Cut Model No. The 917.370931 Does the battery need to be charged before it will start with the pull rope?
no
it is the same as a car with a flat battery
turn it on and then push it and it starts
the same as the mower --turn it on and pull the cord
Jun 08, 2017 | Electric Garden
675 Briggs & Stratton Power Propelled, Electric Start, Model 917376531. Where is battery located?
Margaret, you plug your charger into the battery, the lead or connection for charger is attached to battery and that is where battery is located. Check the attached links,instruction and guides, Good luck Battery is # 74 in link picture.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ubermanuals.com/product/craftsman-917376531-13041
CRAFTSMAN MOWER Parts Model 917376531 Sears PartsDirect
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/917376531.html
Craftsman Washer 917376531 Parts List
How to charge the Craftsman 650 battery start lawn mower model 917 37641
Apr 15, 2016 | Briggs & Stratton Garden
Model 917.370440. Where are battery and fuse located?
On the back right as you walk behind. Follow the shielded wiring harness from the black box on the right side of the handle down to the mower deck. That wire plugs into the battery. Hope this helps.
Jul 20, 2015 | Electric Garden
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
Where can I find a troubleshhot guide for a lawn-boy cordless walk power mower model 10123
Batteries need to be kept warm and charged,on a regular basis,this is where a "Float Charger" comes in handy to monitor battery voltage while in storage ,I'd bet the ranch your battery is toast,but any auto parts store could LOAD test it for you ,Good luck !
Jun 08, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn mower batter charger blows circuit breaker
I'd try plugging it into another outlet first, then try turning off any other appliances that might be on that same circuit. If it continues to trip the breaker, I'd take it to the small engine shop.
hope this helps
Apr 19, 2014 | Toro Garden
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Toro walk behind mower battery will not stay charged overnight,can't find a short
If the battery won't stay charged it most likely needs to be replaced. Check out http://www.batteryinternational.com/electric-lawn-maintenance-batteries.html . They should have the battery you are looking for.
Apr 11, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
