Question about Refrigerators
Refrigerator runs all the time
Fan just seems to run non stop
  • 8 Answers
SOURCE: refrigerator
the compressor might have had it
Posted on Dec 20, 2007
  • 54 Answers
SOURCE: GSS25 side by side refrigerator stopped freezing first and now refrigerator part doesn't stay cold. sounds like a fan is running but when I open the door the fan or whatever is running stops
Is there frost on the back panel in the freezer, If so change the defrost heater. If not is there anything running?
Posted on Jul 03, 2008
ailia
  • 175 Answers
SOURCE: Compressor area above refrigerator is getting very hot
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Regards:
Hassan
Posted on Jul 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: have a GE TFX25JR/TFT25JR refrigeratorfreezer fan runs forever
Look inside the fresh food compartment and behind the control panel and there should be a defrost timer. Part number WR9X489 and that is the only reason that I can think of that would keep the fan running all the time. What I think is the contacts that normally open to let the freezer defrost are fused or welded themselves together. If compressor cycles and temperatures are OK (safe) that leads me to that needing replaced. I will look for the wiring diagram for your model but have found it hard to really get those answers from GE. But most timers are universal as long as the time of defrost and hours between are correct, Let me know, Thanks Sea Breeze
Posted on Apr 22, 2010
Testimonial: "Breeze was awesome, and encorauging, i would have given up without the advice, thanks a million Sea Breeze!"
imufo2
  • 3773 Answers
SOURCE: Refrigerator & frezzer no longer
HI,
Yes, very much. The fan has to be running every time the compressor does/
Check power to fan before you condemn it then replace it.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Posted on Jul 24, 2011
My refrigerator stopped getting cold, but the freezer side still works
There should be a vent with a fan between the freezer side and the fridge side. Make sure the vent is fully open and fan running ok
May 19, 2012 | Maytag Refrigerators
Does not cool either side fan runs and compressor seems to run
2 possible issues. If compressor running, but not cooling - No freon in the system, or compressor valves are bad, not compressing freon. Ideal would be to check pressures on the system while its running. Could be some kind of restriction. most common problem i would guess low freon level. Here are 2 of my videos i have on my channel. first is leak found at evaporator coils. i used leak dye to find it, second video is replacing compressor, but had compressor completely down. installed 3-n-1 hard start kit, but compressor did not come on, so replaced compressor with filter drier. Hope this will give you an idea what to do next.
Aug 19, 2011 | Maytag MZD2766GES Side by Side...
FixYa: We understand that your problem is: I have a 2007 side by side Kitchen Aid Refrigerator. It seem that the motor runs non stop. The coils are clean. The house temperatures are constant and the...
Hi there
Maybe nothing
1. The fan in the freezer compartment runs full time, this could be the motor noise you hear
If the temperatures are OK then it can not be the compressor that is running all the time or the freezer would go really low in temperature.
You need to pull out the unit and confirm that it is the compressor that is in fact running all the time, they normally run around 12 to 16 hours each day
2. The other unlikely possibility is if the compressor is running full time then there may be a fault with the compressor, busted suction valve or the system could be low on gas.
Regards
Gordon
Apr 21, 2011 | KitchenAid Refrigerators
My refrigerator keeps running inside the freezer part ice is forming.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | Maytag MSD2756G Side by Side Refrigerator
Have a GE TFX25JR/TFT25JR refrigeratorfreezer fan runs forever
Apr 22, 2010 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Beer keeps freezing....Compressor/fan runs non-stop...
the thermostat sounds as though it is faulty if it is frosting the entire eveaporator and not cutting out
Sep 22, 2009 | Refrigerators
Freezer fan running non-stop+freezer icing up
very likely that either the defrost timer is not working or the defrost heater is not working.
May 04, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hussman Floral walkin display cooler, has 3 fans but 2 stopped
how hard to work on Walkin refrigerator, and why there is not many people work on those things!
Jan 03, 2009 | Kolpak KOL-SK71213CI Indoor Walk In Cooler...
HOT POINT NOT COOLING WELL
if the condenser fan ( the one near the compressor) is not running and the compressor is running, then that's not good. try to lubricate the bushings of the fan and see if it would run. feel the blade if it turns smoothly. if it's sticcky, then there is your problem.
it should be running the same time as the compressor. if the compressor stops, the fan should stop too.
tnx 4using fixya,
drcool
Sep 26, 2008 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
