Question about Maytag 2.0 Cu. Ft. Over-the-Range Microwave
Microwave will not heat anything
The Maytag Microwave (Over the Range Mount) will not heat up anything. The table turns, the light comes on but it will not heat.
I looked at the white colored fuse but can't tell if it is blown for sure.
Is there something else that could be wrong before I go off to find a 20 amp/250 volt fuse?
I appreciate your help. Money's tight and the last guy charged an arm and a leg to come out and fix it.
It's not even that old. (2005)
He thought I made too much money he said. I'm a Realtor so now what does he think?
  • info39545 May 20, 2009
    Thanks for your help!!
    It appears to be more difficult than I thought.
    I had the door switch replaced before now that I think of it.
    It was very costly at the time.
    I'm so over maytag microwaves. Never again.
    Thanks so much!
    On to a new one and better brand, I hope.
    Sergeant:
    Champion:
  • 214 Answers
To me it sounds like you have a bad thermistat there are 3 i think it was been awhile.You can bypass each one by joining the wires and then run with a cup of water for 2 min.Cheak if the water heats up.Be very carfull for a microwave can hold alot of voltage even after unpluged.If you can you can touch across with a insulted screw driver on the capaciter it is a silver.After cheaking the them and no go you may have a fualty door switch.Hope this helped:)
Posted on May 20, 2009
MICROWAVE WILL START THEN TURN TABLE STOPS LIGHT GOES OUT AND STOPS HEATING THEN COMES ON AND OFF ANY SUGGESTIONS
Check the door switches. If they are good check the thermal cutouts. Check the connections on the control board.
Nov 12, 2014 | LG Over-the-Range Microwave
Turntable is not turning the heat is not coming on
Chances are it has a bad top or bottom door switch or door switch mount.
See my help files here:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 26, 2013 | Maytag Appliances Over-the-Range Microwave...
Maytag Microwave over Oven: comes on with lite and table turns; loud continuous noise and doesn't heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 21, 2011 | Maytag 2.0 Cu. Ft. Over-the-Range...
Our microwave (CFMV156DCF) wont heat or defrost but when you shut the door the light comes on and the turn table turns. The fan and light buttons also work. Do you know how this can be fixed? Thank you.
You probably have a bad door switch or door switch mount.
Our file on door switches is here.
The full service manual for this model is at our site here.
You can order parts by entering your full model number or part numbers here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 01, 2010 | Frigidaire FMV156DC Microwave Oven
JVM2070SH001
you have a bad magnetron. go to sears parts direct and you can see the price for a new one. but it may not pay tp fix.
Feb 25, 2010 | GE Profile Spacemaker Over-the-Range...
MICROWAVE NOT WORKING PROPERLY
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Otherwise, it sounds like a bad door switch or door switch mount.
Aug 20, 2008 | Daewoo Microwave Ovens
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
MICROWAVE WILL NOT HEAT
check the connections on the h.v side because the unit works on 4500 volts and if there are any bad connctions it will not reach its working voltage and will not energize.remove all the connections 1 at a time and tighten all the terminals and try it again.you will not be able to test the components with a digital multimetre as it does not have the range.you need an analoge unit with a 10k scale and a 9 volt battery inside or it will give you falsr readings.teh diode which is thge little black unit with 1 side down to earth should read half way with the laeds on 1 way then when you put it on the opposite side it should not move.the capacitor will make the needle of the multimetre flick up when put onto the terminals both ways.the magnetron should have a short reading on the terminals but with 1 connected to the terminal of the input and 1 to the case it should not read at all,hope this helps regards les
May 15, 2008 | Maytag MMV4205 Microwave Oven
Turntable will not spin
This is usually a probem with a door switch or door switch mount or a problem on the control board. We repair these control panel assemblies for $39.95 nationwide.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 12, 2007 | Maytag MMC5000 Microwave Oven
Maytag 2.0 Cu. Ft. Over-the-Range Microwave Logo
365 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
