Question about Singer 2263 Mechanical Sewing Machine
Blanket stitch foot for singer 401 - Singer 2263 Mechanical Sewing Machine
  • 4 Answers
SOURCE: Hi I have a cee100
i spoke with support and they tell me that this is a threading issue. pull the thread back and forth, like flossing, under the plastic plate on top so the thread clicks into place. then procede with threading.
Posted on Dec 17, 2008
  • 22 Answers
SOURCE: Top stitch looks good, bottom stitch is loopy
this is a common problem, don't worry it's easy to fix.  take the spool of thread off, remove the bobbin.  look for any stray thread pieces in or around the bobbin case, rethread the top of the machine and when you do, follow the threading guide precisely and ---here's the trick---make certain that the thread goes between the tension discs.
Posted on Jan 17, 2009
HansPP
  • 2510 Answers
SOURCE: I have a Singer model
An accredited Singer agent/dealer should be able to supply or order the part for you.
Posted on Jan 25, 2011
  • 1788 Answers
SOURCE: what are the settings for a blind hem stitch?
I downloaded your manual for free at www.singerco.com and I be darned, I see why you are baffled. Call Singer at 1-800-4singer and ask them to tell you. This is a first for me to see in a machine that is not that old, my 45 year old Kenmore has the blind stitch setting. There has to be some answer to this.
Posted on Apr 20, 2011
SOURCE: wiring a foot control pedal for Singer
I have a singer advance 7422 and the outlet for the foot controller is kind of broken. A few days ago a little round black thing fell out of the outlet and now when i try to connect the foot controller it is very loose and the machine doesn't run. what should i do?
Posted on Jun 28, 2011
I have a singer sewing machine model 1 I am wanting to order a blind stitch foot. I don't seem to be able to locate can you help me?
Hm, if you talking of a blind hem foot, this indicates that one came with the Singer One.
1 ONE Singer Sewing
It appears your machine has a snap-on foot capability, so if that is the case, a snap-on blind hem foot should work.
http://www.sewingpartsonline.com/blindhem-foot-singer-006812008.aspx
Apr 01, 2017 | Singer Sewing Machines
Is singer contessa 974N compatible with flower stitch foot
You may want to contact Singer directly. They will be able to determine if the flower stitch unit is compatible with your machine.
According to the Singer site, it doesn't look like it is:
Flower Stitch Presser Foot Attachment
This one will fit any low-shank machines:
Decorative Daisy Flower Stitch Sewing Machine Presser Foot Fits All Low...
Here are some sites that will help you determine what shank your machine has:
Sewing Machine Feet
Amazon com Questions And Answers how do you know if your sewing machine is...
Will This Presser Foot Fit My Sewing Machine Sew Much EasierSew Much Easier
Once you know the shank of your machine, you can then try to locate a flower stitch accessory that will work on your type of shank.
Sep 03, 2016 | Singer Sewing Machines
Hi I'm new to sewing! Does my singer have a blanket stitch
Your machine is a beginner model with only 8 stitches. Looking at the photo of the machine, it does not appear to have a blanket stitch.
Singer 1507 Sewing Machine
Usually, only more advanced (and expensive) machines with more stitches will have the blanket stitch.
Nov 08, 2015 | Singer 1507
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Foot for quilting
I would use a foot that can do a zig zag stitch or a blanket stitch
Oct 01, 2012 | Janome D'cor Excel 5018
FIND MANUAL FOR SINGER MODEL 1748
Go to the singer website--free pdf download
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 1748) & click search
Jul 27, 2012 | Singer Sewing Machines
I have a Singer 327K that stitches three or four good stitches and then stops completely stitching
it's very possible that when the needle broke the machine went out of time & would have to be retimed at a sewing machine shop
Mar 10, 2012 | Singer Sewing Machines
Wiring a foot control pedal for Singer Slant-o-Matic 401G sewing machine, banana socket. The machines listed are newer models and my 401 is not listed.
Faboulous machine the 401 and the best machine ever made, in the UK if I remember the two red wires go to the right hand pin and thw two blacks go to each terminal, when you rewire the plug which is fidly undo the stop motion, when you plug the machine in if it runs on without touching the foot control change the two black wires over, to rewire the foot control there are only two wires, you can't go wrong.
Jun 11, 2010 | Singer 7422
I have a Singer 401 A sewing machine. Nylon material will not move across the foot plate when I am sewing. The tension of the foot seems good. It was working then all of a sudden it stopped moving. I...
By saying the tension of the foot is good I take it you mean the pressure is set good. Maybe add more pressure. Are you sure that the lever on the bottom right is set for sewing and not darning which raises the needle plate above the feeddogs? Sure that your feed dogs are moving well at the stitch length set. With slippery fabrics you may need to try a different type of foot. There are some plastic or teflon coated ones that will not stick to or hold the material back. Or try a Walking Foot or Even Feed foot which will move the top of the fabric evenly with the bottom.
They do help alot.
Good luck
Apr 22, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 2263 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
