Question about Tag Heuer TH 5104 Sunglasses
Right arm broken - Tag Heuer TH 5104 Sunglasses
Broken lifter arm 96 honda prelude?
Interesting question. If you think a lifter arm, which I presume is also called a rocker arm, is broken, remove the valve cover and find it. All the rocker arms are visible, and should be easy to see.
May 05, 2014 | 1996 Honda Prelude
Tip
Canon Imageclass MF6500 Series Copier with Blank Copies Prints Problem
This tip works on all Canon Imageclass 6500 series machines including the MF6500 MF6530 MF6531 MF6540 MF6550 MF6560 MF6580 MF6590 and MF6595.
First of all if you are experiencing blank copies and or prints the best thing to do is try a different toner cartridge. In rare cases the black copies/prints CAN be caused by a defective cartridge. In MOST cases it is caused by a broken or detatched laser shutter lever or arm. When a toner cartridge is inserted and the door closed, a small plastic arm opens the laser shutter. If this arm is broken or has become disconnected then the shutter is not opened. This blocks the laser from writing the copy or print image onto the drum and this results in no print being applied to the paper. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
on Nov 02, 2010 | Office Equipment & Supplies
I have my persruiption in my gucci 3017/s black and I nee a new left arm
I know this is an old post, but I need a new right arm! What did you end up doing with your glasses?
Oct 17, 2011 | Gucci GG 3017 Sunglasses
Lower right control arm is broken need schematic to figure out what to replace
What is broken,the aluminum arm?
How and where is it broken?
Shouldn't need to figure out anything,just remove it!
Sep 24, 2010 | 2000 Lincoln LS
I have a Zub Zero 650 refrigerator (top) freezer (bottom) that is 10 years old. The ice maker has a grey plastic arm to the upper right. Ours appears to be broken off at one end. On one side of this...
Yes, they should look the same. This bracket helps to turn the ice maker off to prevent over flow. Guessing by the age I believe you have a 650 or a 650-2. The part number for this is 7014671 and it is called a ice maker rudder arm. Go to http://subzero.com/locator/index.aspx to locate your local parts supplier. If you look inside the door jamb you will see your model and serial number. Give this to the parts house to ensure you get the proper arm.
Sep 19, 2010 | Sub-Zero 650 / O Bottom Freezer...
ImageClass 6530 copies and prints blank pages.
This is either your toner cartridge or more likely the plastic arm that opens the laser shutter is broken. When you insert a toner and close the access door, there is a plastic arm that opens the laser shutter. If this shutter does not open it blocks the laser and results in blank copies. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Mar 19, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Knocking or ticking in the engine, under the valve cover ticking under valve cover in 94 cavalier i think it is the rocker arms
you are right its either a rocker arm broken or loose or it also could be a broken valve spring so look for all three While you have the valve cover off to save you coming back and looking again ... thanks Jerry
Apr 22, 2009 | 1994 Chevrolet Cavalier
Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Apr 28, 2008 | Maytag Performa PAV2200
Tag Heuer TH 5104 Sunglasses Logo
Top Tag Heuer Clothing Accessories Experts
Da Doc
ray gallant
Tom Chichester
Are you a Tag Heuer Clothing Accessory Expert? Answer questions, earn points and help others
