Question about Brother HL 2270DW Laser Printer
Brother 2270 drum unit stuck inside of printer
SOURCE: brother hl 2040 drum unit assembly installation
I was trying to put it in the wrong side of the printer!
Posted on Apr 14, 2008
xptareq2000
  • 1447 Answers
SOURCE: paper jam brother mfc8840
It is problem your copier drum unite replace it & solve problem
Posted on Jun 11, 2009
SOURCE: Brother Laser Printer, paper gets stuck and printing wipes off.
Opened up the back and found there is a plastic cog wheel on the end of an orange drum, which must be the Fuser Unit, which was damaged. So the paper was getting as far as the drum but the rollers to pull it through the Fuser Unit were not going round. A new Fuser Unit seems to be about £99 plus VAT and I don't supose a new printer is much more than that. So if anyone has a spare Fuser Unit for a Brother HL 5140 which is still in good working order I would be happy to consider buying it. Alternatively I have 2 x spare drums DR3000 and 1 x toner TN3060 for sale !!
Posted on Oct 26, 2009
  • 21 Answers
SOURCE: II have a Brother mfc 7420 and at first I could
pull out the drive release cam and then remove drum unit. I think that the hook on release cam is broken
see image
Posted on Jun 24, 2010
djgillstudio
  • 107 Answers
SOURCE: I just replaced the drum
hello, first did you follow instructions of reseting machine when you replaced drum, if not here is the istructions, with machine in ready state, press go button and up arrow at same time, the reset parts life comes up, use up arrow or down arrow to scroll thru to drum replacement, press the ok button when you get to drum, the machine will have drum unit ok?, press okay, machine will cycle and reset drum.
Posted on Nov 03, 2010
What is error 32
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
May 20, 2011 | Brother MFC-5890cn Color Flatbed...
Brother 2170W, toner is stuck after paper jammed. I try to pull out the toner (even with force!) but it stuck, there is a paper at the bottom that i can't pull either. I guess this paper holds the...
If the paper get stuck inside the printer you can also remove it fro the back of it. Open the back cover and try to remove the jammed paper inside of the printer. If still the paper can't be remove try again to removed the drum and toner.
Open the front cover or pull down the cover right above the brother logo infront of the machine then hold the handle of the drum and toner assembly.Pull the drum and toner assembly towards you, just put a little force on it. Then remove the jammed paper.
Just to make sure, remove the toner from the drum by holding down the tab on the side and lift the toner out. Look for any small piece of paper inside of the drum unit. Reinstall the toner back to the drum. reinstall the drum and toner back to the machine, make sure that you here a click sound. After that close the front and back cover.
The blue light should lit up again.
Hope this helps. Thanks
May 06, 2011 | Brother HL-2170W Laser Printer
HL 2140. How do you remove jammed paper from inside printer
You can remove the jammed paper by removing the drum and toner inside the printer.
First Open the front cover, just pull down the cover right above the brother logo. You will see the handle for the drum and toner. Hold the handle and pull it towards you, just use a little force on it. Then remove the jammed paper inside. Just to be sure you can remove the toner from the drum by holding down the green tab on the side of the drum unit. then pull the toner out. Check if there's a small piece of paper inside the drum unit. Put the toner back to the drum make sure it clicks into place. Reinstall the drum and toner back to the printer. It should also click into place. Then close the cover.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother HL 2140 Laser Printer
How do I access and change out the toner cartridge? (brother HL-2140 printer)
1 Turn your Brother HL-2140 laser printer on.
2 Open the front cover by pulling the top latch toward you.
3 Pull the printer drum unit toward you. Put it on the clean, blank sheet of paper.
4 Push the green lever on the drum assembly down.
5 Remove the empty toner cartridge from the drum unit.
6 Shake your replacement toner cartridge gently to evenly distribute the toner inside.
7 Put the new toner into the drum unit and slide the unit back into your Brother HL-2140 printer. Close the top cover.
See also Brother user manual for this model at: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Feb 25, 2011 | Office Equipment & Supplies
Red paper light is on even though there is paper in the tray. brother 2040 model.
This is a paper jam. Remove paper try as well as the toner/drum unit. Take vacuum and clean out inside the printer. Separate the toner & drum units and vacuum-blow out the drum unit to get it clean. Run the drum wire cleaner tab (purple/blue tab at front of the drum unit) back & forth a number of times. Sounds like you've got a piece of paper stuck inside somewhere. In the back of the printer, there is a door that will open out and down...check here for a speck of paper that is causing the paper light to come on...it "sees" something is in the way) since this is where the paper curls up and out the top. Reassemble toner/drum unit. Before you put the paper tray back in, take a piece of paper and feed from the front (use light card stock or heavy weight paper since this will help push out anything inside that's in the way) and print a few pages this way. Then, make sure your paper is dry (hasn't been in humid area) and is lying flat (not curled at edges). That should do it
Dec 21, 2009 | Brother HL-2040 Laser Printer
Oct 25, 2009 | Brother HL 1440 Laser Printer
Sticker label stuck inside
Depends on where inside the machine the label got stuck. There's covers on the back, front (which also lets you remove the toner/drum unit for more access) and also the paper tray.
If you're unable to reach the label removing these parts/opening the covers, the machine would require to be screwed apart to reach it. There is no levels to release pressure on drum or similar to reach further within, unfortunately.
Jun 02, 2009 | Brother HL-2040 Laser Printer
Paper jam brother mfc8840
May 21, 2009 | Brother MFC-8840D All-In-One Laser Printer
Printer is printing BLACK PAGES
Solution from brother
Jul 11, 2008 | Brother HL-2040 Laser Printer
Brother HL 2270DW Laser Printer Logo
21 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
