SOURCE: AEG Lavamat 86720 washing machine
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
post further comment for more help......
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
SOURCE: washine machines
Yes. There is a part that allows you to connect the cold water supply to both the hot and cold inlet hoses. It has worked successfully on our 6100 for 8 years or so. I think it was part of the original kit rather than a subsequent purchase - it's a Y-shaped yoke with an inlet connection and two outlets that accept the two hoses feeding the inlets of the machine. From memory i tink the situation is mentioned in the user manual somewhere.
SOURCE: AEG Lavamat 518 manual
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
