Question about Sony KDL52NX800 52 in. TV
Factory reset Tried up arrow and holding power button to reset and no response...tv does not shut off.
3 Suggested Answers
  • 89 Answers
SOURCE: When I turn sony kdl32m4000 on, green power light comes on but
I understand that your TV is turning ON but you're not bale to view the videos on the TV screen. If the TV is connected to a wall outlet through a Surge protector please disconnect the connection through the Surge protector and try connecting the TV to a working wall outlet and check if that helps. Please check the connection between the TV and the connected device. Please try using a different device and check if that helps. This is to check whether the issue is with the TV or the connected device. Please try to explain the issue as much as you can next time. What are the video sources connected to the TV? Does this issue occur with the TV when connected to other devices? How did you connect the videos sources to the TV? Which connection are you using to connect the devices to the TV? You TV doesn't support 1080p resolution, so please check whether the connected device is giving output in 1080p resolution. If the issue still persists service of the TV is recommended.
Posted on Jun 16, 2009
  • 4234 Answers
SOURCE: Sony Bravia 32". After Powering On within 5
In order to properly diagnose the problem and provide a solution, the following information is required:
1) Model number (on the back of the set)
2) The count of blinks of hte standby light.
The standby light should be blinking in a repeated pattern of a count followed by a short pause then the count again ...
This count is an indication of the circuit that has the fault. With that information and the model number, I can list the likely causes and fixes.
Thanks,
Dan
Posted on Aug 23, 2010
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
None of my inputs work on the TV, including the Ethernet connection
test with your cell phone directly then reconnect the modem last reset tv to do so in main menu
Sep 15, 2015 | Sony BRAVIA KDL-55EX710 55" LED TV...
HOW DO I CHANGE MY SONY LED TV FROM ARABIC WITH ENGLISH
You would need to do a factory reset
From the Sony Forums:
factory reset to your Television.
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button.
  4. While holding the UP ARROW button, with your other hand reach around the side of the TV and press and release the POWER button on the TV set.( not the power button on the remote) it should be the top button along the side panel.
Sep 06, 2014 | Sony BRAVIA KDL46EX720 46 Inch 3D 1080p...
Nothing is plugged into the tv ATM all we have is power you turn on the tv and the standby light flashes as you can see in the video. Normally any button on the tv's remote and it comes on but nothin
  1. id suggest resetting the tv by:
    Press and hold the up arrow on the remote.
    Make sure that the remote is facing the television and is not obstructed
Press the power button on the Sony TV. Press the button on the television itself, not the power button on the remote. You can release the up arrow after you press the power button. The television will power off and then power itself back on with all of the settings reset to their original factory defaults.
Nov 09, 2012 | Televison & Video
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Have lost all my hd tv stations
Hello
Just reset the TV to factory settings and retune it using auto tuning fuction from the Menu option.
To reset it to factory settings, do the following:
Turn on the TV. While holding down "UP arrow" button on the remote control, press the POWER button on the TV. [The TV will turns itself OFF and then back ON again. Release the "Up Arrow button.
This operation will clear all your customized settings including Paremtial Lock settings.
in otherwords, this is the process to unlock the TV if it is locked.
Retune it by autotune fuction. All the lost stations will emerge again.
Ok.
Jan 20, 2011 | Sony BRAVIA KDL52XBR2 Television
I DONT REMEMBER THE CHILD LOCK CODE ON MY SONY TV IS THERE ANY OTHER WAY TO TURN IT OFF
Reset it back to factory settings
  1. Turn on the television.
  2. On the TV remote control, press and hold either the RESET or UP ARROW button.
  3. While holding the RESET or UP ARROW button, press and release the POWER button on the front of the TV. NOTE: The TV will turn off and then back on.
  4. Release the RESET or UP ARROW button.
Apr 25, 2010 | Sony FD Trinitron KV-28FQ75 28" TV
Tv shut itself off,will not turn back on
spoiled fly back transformer which needs replavement
Sep 25, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Sony KDL52NX800 52 in. TV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
