Coleman furnace im getting a reversed polarity reading on the flash code diagnostics how do I fix this
  • 451 Answers
Reverse polarity means the power wires coming to the furnace are connected backwards. The black wire should the hot ( 120 volt line) . The white wire should be the neutral. The green should be the ground. Check these connections and test them to make sure they are correct. You should get 120 volt reading between the black and white.120 volts between the black and green and 0 volts between the white and green. Hope this helps.
Posted on Jan 02, 2014
Testimonial: "the only thing I don't get is if I shut the power of to it and leave it for a while it will come on it ran all night lastnight and now I cant get it to work for anything what would cause this the motherboard or what ever you call it was just changed Tuesday morning and it was working fine now the reverse polarity code if flashing"
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: have to replace ignitor on coleman furnace every year
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
Posted on Dec 04, 2008
  • 4 Answers
SOURCE: Fix for coleman rv furnace
Check all limit switches and check power to gas control
Posted on Jan 06, 2009
gear001
  • 59 Answers
SOURCE: reverse polarity
Its a simple fix. Follow the cord that plugs into the wall into the furnace. Or if its hard wire, follow the romex wire that goes into your furnace. Inside the furnace, switch the white and black wires that connects to the power cord. www.fastacservice.com
Posted on Oct 18, 2009
Bryant plus 80 furnace no fan/ operation , yellow constant flashing light code , power to furnace was rerouted during remodel and since then furnace stopped working. Any suggestions ?
You need to have/ know the "fault code" chart for that specific furnace. Count the number of flashes and refer to chart. Look on the inside of the furnace blower door or other panel. Also look up on internet and print it off. If the furnace was allowed to run during the remodel it voids the warranty automatically. Read the installation manual.
Try resetting the electronic board by turning the power off then back on.
Mar 29, 2017 | Bryant Heating & Cooling
I have a Goodman GMP 125-5 furnace. It had a 3 light code i replaced the presure switch now it is giving me a 1 light code please help
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Oct 28, 2011 | Goodman Heating & Cooling
I have goodman GMP series furance the furnance and gas comes on and fires up then goes out flame sensor is good what else could be wrong
Improper ground from control to burner.
Incorrect electrical wiring, check polarity.
Tubing partially clogged between inducer and proving switch.
Oct 18, 2011 | Goodman GMS90703BXA Heater
Coleman evcon wrong polarity or twinning error what does this code mean
It will probably means you have your hot and neutral wires crossed. The furnace has 120 volts coming in to it from your house. If the hot and neutral wire are wired to the furnace wrong, it will show this error. Take the electrical box loose where you can see the power cord coming in to the furnace. (turn off the circuit breaker to the furnace) Take the white and black wire loose , connect the black where the white wire was and the white where the black was. All you are doing is reversing polarity. I hope this works for you.
Apr 18, 2011 | Coleman Heating & Cooling
Suddenly not working im not sure if there even is a pilot to be lit
Goodman have troubleshooting idiot lights on the board. Look for flashes and count em.
The flash explanations are printed on the backside of the blower cover on most models.
Feb 03, 2011 | Goodman Heating & Cooling
Hi, I have a Janitrol GMPN060 natural
HI Check you air filter in clean , jump out the pressure switch see if it starts are the fan motors clean also check out the fan control hope this helps
Feb 12, 2010 | Heating & Cooling
Gas furnace; flame will not stay on
Clean the flame sensor with a green scotch brite pad. Check all ground connections from the circuit board to the furnace cabinet. Check for a proper ground to the electrical box. Make sure polarity has not been reversed.
Dec 26, 2009 | Coleman Heating & Cooling
Coleman evcon Dgato7obdc
Small blower motor? Are you talking about the combustion blower if so then check your vents for blockage.. if the vents are blocked won't work... if it has a control board init it will give you a diagnostic code. Flashing light on the board... count the flashes and look up the fault on the chart in your owners manual ot on the furnace door..
Jan 13, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
