Question about Exercise & Fitness
House was struck by lighting. control panel lights jump all around and treadmill wont run at all
  • leslie
    leslie Jan 05, 2014
    treadmill is a proform 760ekg 29167.0
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Whats the make, model and serial of your unit?
Posted on Jan 04, 2014
  • Techmotionusa.com
    Techmotionusa.com Jan 06, 2014
    If your timer goes when you press start, you have either a blown controller or your motor is shot. Use a 9v battery and connect the leads of your motor to the battery. If it turns, your motor is good. Replace the controller. If when you press the start button the timer does NOT go, then replace your console.
5 Suggested Answers
  • 1212 Answers
SOURCE: apex 4100i nordic track treadmill.
Check the fuses on the motor control board, under the lower hood. There are usually 2 of them, and they are ceramic so you need to test them for continuity with a meter or test light/ buzzer. One is usually 10 amps the other is usually 15 amps.
These will blow when the treadmill is used on an electrical circuit that is inadequate for the mill. The way many houses are wired today leads to this issue. You can trip the reaker int he box so the affected branch is no longer energized and follow the wiring- at each outlet, remove the cover, and look to see if the wires are just stabbed into the back of the outlets. While this is acceptable for code, it is not acceptable for loads like a treadmill. Most of the time the wires cannot be extracted without damaging the outlet, so get enough outlets for the run, and with the new outlets, make sure to attach the wires under the screw heads. Black (sometimes red) to brass screws and white to silvery screws. and make sure the ground wire is attached to the green grounding screw. If you would rather an electrician do it- that is a good idea, and make sure they put the wire under the screw heads,. Form a loop in the wire clockwise as this is the direction the screw tightens, if the loop is clockwise it will stay under the screw head.
While this may not eliminate the problem of fuses blowing in all cases- in those remaining cases heavier wire must be run to the outlet the treadmill is plugged into.
Posted on Jan 25, 2012
ercupa190
  • 12223 Answers
SOURCE: My ultrafit treadmill won't run-the control panel
2_15_2012_4_45_37_pm.gifAdjust the reed switch as indicated by the diagram by 1/8- 1/4". Run the calibration software instruction under the Hood motor or see your user manual.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 15, 2012
ercupa190
  • 12223 Answers
SOURCE: My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Posted on Jul 23, 2012
  • 7 Answers
SOURCE: Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Posted on Feb 19, 2013
Treadmill LS10.0T Runs & inclines When slowing down treadmill it will shut down, the power switch is in 'On' position but light on switch goes off and back on. Is this a switch issue or a motor issue
Check the wiring from motor control board to control panel.
If you wish to get some details about treadmill repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 27, 2016 | Exercise & Fitness
2004 envoy won't start after my house got struck by lightening. Coincidence?
Yes the lighting likely burned out the car's electronic control module(s). Contact your insurance company, this can be a very expensive repair.
Sep 18, 2016 | 2004 GMC Envoy
Clubtrack 3.0 Plus. Why won't it turn on?
This sounds like a Faulty Motor control board.
Nov 01, 2015 | Exercise & Fitness
Apex 4100i nordic track treadmill.
Jan 24, 2012 | Exercise & Fitness
When turning reebok tr3 on the digital display goes off and green light stays on english led and treadmill doesnt work
1) Try to exchange batteries new ones.2) see the diagram adn adjust by 1/8" or 3mms according. 3) tight the key panel flexible cable vs display board 4) then connector display board vs lower board.5) test the main motor controller bOARDEC for 5+vdc, to display board.See the block diagram how the main motor controller has 90% aprox for control functions of any treadmills.sincerely. Merry Christmas.ernesto cuadra , managua, nicaragua. 12_20_2011_7_10_29_pm.gif12_20_2011_7_10_45_pm.gif
Dec 20, 2011 | Exercise & Fitness
Lumix wont turn on the battery is good there are no lights coming on and what was happening before this is the lens wouldn't retract when powering off
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Lumix service as you do not have to run around for spares.
Jun 22, 2011 | Cameras
The Cateye ec t220 treadmill in our exercise room no longer has a functioning display. Nothing lights up. It is possible a power surge blew out a main circuit or something of that nature- we are on a...
If your treadmill was struck by a power surge unfortunately there is no way of fixing it, in fact it is a fire HAZARD. Basically a back-flow of electrical current has fried the appliance from the inside.
A good way of checking if this was the problem is to check smaller appliance's around the house that were plugged in around the same time the treadmill stopped working. Even if appliences are turned off at the switch they can still be effected.
If you have no problems with any smaller appliance then we can more or less rule out a power surge. Have you tried dissembling the plug, changing the fuse, moving the treadmill them plugging it in to a different socket? .......yes?
Then as this model is no longer in production i suggest you phone 303-443-4595 for advice as this is the North America helpline for cateye.
Feb 15, 2011 | Cateye Fitness Cateye® EC-T220 Treadmill
LD light
umm. thinkin perhaps something flaoting around on the drain pump house perhaps causing partial restriction of drain capability.new pump doesnt maen something cant get struck in impeller
Oct 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Exercise & Fitness Logo
26 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
