2000 explorer keeps fouling number 1 plug
SOURCE: Spark plugs are fouling out
Build up on the spark plugs due to dirty oil being used. Maybe before selling it to you.Some other problems could be happening. for example, Bad fuel, bad timing etc.
SOURCE: runs rough and keeps fouling out new spark plugs
sounds like too rich of a mixture check for vacuum leaks and check fuel press regulator
SOURCE: Shrill noise and fouled spark plug
Yup - its conected.. Its more than likely a head gaskit or cracked head.. Did it get really hot ?
Hope this helps !!
rate me good ;o)
SOURCE: oil in number 1 cylinder, fouling out plug
is there oil actually in the cylinder? or is the oil in the tube that the spark plug body lives in? if it's just in the tube, then you only need a valve cover gasket set which comes w/ a round rubber seal for the top of each spark plug tube. if however, the oil is actually in the cylinder, then you either have a faulty piston oil ring or faulty valve seals. the repairs for rings/seals are a giant PIA. let's hope it's just the valve cover gasket set
SOURCE: I got a 1999 gmc suburban and the number 6 spark
I had the same problem. To see if it was a bad a wire, I switched the spark plug wires on #6 and 8. Haven't had a problem since. I think it might have been the plug wires being re-seated when I swithced them took care of it.
Several factors can contribute to spark plug fouling:
- The air/fuel
ratio may be too rich as a result of incorrect carburetor adjustment or a poorly
performing fuel injection system.
- Worn piston rings or valve seals may allow too
much oil to leak into the combustion chamber, leading to oil fouling.
- The
ignition system may not be performing properly.
- Prolonged idling or continuous
low-speed driving may keep the spark plug from reaching its optimum operating
temperature. Using too cold a spark plug can lead to the same problem.
- A dirty air cleaner can create a too-rich condition which can lead to
fouling.
Have each of the above checked and corrected.
Fuel, oil and carbon fouling can all be the result of different
causes but, once a spark plug is fouled, it will not provide adequate voltage to
the firing tip and that cylinder will not fire properly.
In many cases, the
spark plug cannot be cleaned sufficiently to restore normal operation.
Hence, I always recommend that a plug be replace, once it becomes fouled.
Cheers,
Scott
"If this has helped you in any way, please be kind enough to rate this solution"
