Question about Radio Communications
Midland 48 excel reset - Radio Communications
Can a midlands 48 alan be used in ireland
anything can be used anywhere until you get caught with it. I think all it needs is to be modified to Irelands standards and you should be fine.
Jun 02, 2014 | Midland Radio Communications
The awi lights on a midlands alan 48 does what
AWI stands for antenna warning indicator. now you know.
Midland 48 excel
get a can of electrical freeze,spray it on the final after the radio shuts down and see if it comes back on. Do it to all the IC's to find out which one it is than have a tech look at it and let him fix it.
May 11, 2014 | Radio Communications
Hi i have a midland 38 plus cb but the recieve is poor i have an excelent swr is there anything i can do to turn the receive up inside?
there is but if u get it wrong then you are stuft. i would just try the earth first cause altho the swr is good if the grounding is poor this will effect sigal.depending on mounting will depend on earth solution
May 01, 2011 | Midland 40-Channel CB Radio CB Radio
When driving over rough ground my midland alan 48 plus multi cb will sometmes change channel on its own i wondered if this could be a mike problem as you can change channel from the mike
Check for loose buttons, could be something loose inside, if its changing on its own when its moving around could be from vibration that something has come loose.
When parked just try shaking the mic first if that doesnt do it shake the cb itself and see if the problem persists
May 18, 2010 | Midland Radio Communications
Midland alan 48 plus transmit scale not moving
Sorted now, soldered a new output transistor into the board and all working.
Dec 11, 2008 | Midland Radio Communications
Radio Communications Logo
65 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
