Belkin wireless bluetooth keyboard doesnt type even though there o
The light flashes etc but no typing. Could it be that i am using a 1.5 plug in.? Do i have to use usb to charge. Help!
listeur
  • 88 Answers
SOURCE: Keyboard typing wrong characters
turn off the keylock on boot- this is an option in the bios. also you might be able to use the fn key and turn it off manually
Posted on Nov 24, 2007
  • 10 Answers
SOURCE: mouse touchpad, keyboard, and usb drives will not work
One thing you can try (for the touchpad)
Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
Hope that helps for your touchpad
Posted on May 05, 2008
Joed911
  • 4338 Answers
SOURCE: My Belkin Bluetooth USB Adapter is asking for PIN number?
The default pin numbers are 0000 (zeros) or 1234.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 23, 2008
yooperbud
  • 8637 Answers
SOURCE: keyboard (laser)
Did you replace the batteries in the wireless keyboard? If not try doing that first and then use the following info.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 20, 2009
vkcelik
  • 77 Answers
SOURCE: the keyboard is typing a 5 instead of an i, a star
Press fn+num lk (scrool) key on the keyboard and see if it works..
PS: Please rate this solution
Posted on Mar 12, 2009
My iPhone 4 (4.1) doesnt get connect with Mobile Wireless Keyboard? (Mexico)
It looks like the type of keyboard and mouse you are using is not bluetooth. You can't use the iphone 4 with just a wireless keyboard. It has to be a BLUETOOTH keyboard.
The Keyboard/Mouse combo you have from verbatim is most likely using Radio Frequency (RF) like the same frequency a TV remote control would use. Bluetooth is a different type of wireless technology that has to be paired with your iphone for it to work.
Mar 16, 2011 | Verbatim Keyboard,Wireless,Multimedia,With...
The keyboard doesn't work, even though I just changed the batteries. Now what?
>when wireless keyboard or mouse runs out of battery, you need to re-establish the bluetooth connection in order for them to be functional again. To do so, you need to press the connect button on the keyboard and the USB dongle connected to the computer at the same time for about 8-10 seconds to establish connection. After that, you can try typing again. Same thing applies to wireless mouse.
Oct 03, 2010 | Gear Head WIRELESS keyboard/Mouse
For some reason the light above the WPS button keeps flashing red. I have tried multiple reboots, none of which have worked. when connected to the ethernet modem, the light stays as a solid red color.
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 16, 2010 | Belkin Wireless Play Router (F7D4302)
Hi...my wireless keyboard stopped working. I
Yes, press the button underneath the keyboard and thenn the button under the mouse.
Apr 26, 2010 | Belkin Wireless Keyboard/Optical Mouse...
Ms 8000 mouse pairing code
You choose your own code. It's a keyboard right? So it has numbers on it...and an Enter key.
1. Press and hold in the small button next to Bluetooth symbol under the keyboard for 5 seconds. The charge indicator lights at the top of the keyboard should alternate flashing red then green.
2. Search for Bluetooth devices on the devices you wish to connect the keyboard to. The Keyboard should be listed there.
3. Enter a code of your choice into the device you are paring the keyboard to and submit it. I used a 4 digit number which worked without a problem.
4. Type the same code and press Enter on the Microsoft Wireless Entertainment Desktop 8000 Keyboard.
The keyboard should now be paired with your device.
Good luck, - GregAndo
Jan 29, 2010 | Microsoft Wireless Entertainment 8000...
My dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Nov 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Nov 12, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
There is a red and green led flashing, and the keyboard doesnt accept any typing commands
This means it's lost its Bluetooth signal. Re-run the BT setup and you'll be fine
Sep 22, 2009 | Microsoft Wireless Entertainment 8000...
Nothin works and nothin is detected
doesnt need batteries does it dl latest driverers form website maker try ohter ports
Oct 09, 2008 | Microsoft Wireless Optical Desktop Comfort...
Key board doesnt work
Nov 07, 2007 | Kensington Comfort Type Wireless Optical...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
