Question about Refrigerators
Model ed20tk whirlpool refrigerator
How do I gain access to change the light switch on the refrigerator side of my refrigerator
peyton32034
  • 410 Answers
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
Posted on Jan 07, 2008
  • 56 Answers
SOURCE: Sub Zero 690 replaced lights but fan and lights dont work
The fan will only run when the compressor is running. Check it a couple of times to see if it actually is not going on. There is alos a light terminator located behind the fan cover. We will assume it is the light switch. For the light switch go to http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code. This will take you to a locator to find the authorized parts distributor for your area I believe the part number for the light switch is 3060140 have them check it using your model and serial number. Once you have the part remove the three phillips head screws that hold the grill in place, this is assuming you don't have the louvered grill. You access these inside the fresh food and freezer compartments. With the door open you look up in to the metal you will be able to see them. Once you get the grill off there is a grey power cord with a white quick connect disconjnect this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for your life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor. If this is too much the link above also is for authorized service in your area.
Posted on Dec 27, 2008
peyton32034
  • 410 Answers
SOURCE: Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Posted on Feb 07, 2009
SOURCE: Change water filter on Whirlpool side by side Refrigerator
Jill, download the instructions here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202205958.pdf.
Posted on Jun 07, 2009
  • 2468 Answers
SOURCE: I have a whirlpool side by side refrigerator model
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Posted on Mar 02, 2010
How do I replace cold control on a whirlpool refrigerator
These are not to hard to replace. You will need to gain access to the control panel to change this part. Once inside there are tabs and wires that will need to be removed.
Here is a diagram of the control panel.
Oct 20, 2012 | Whirlpool Refrigerators
Overheating of Partition in a side-by-side
pull off the bottom front kick panel and check the condenser coil to see if it's filled with dust,also pull out the machine and remove the back bottom panel and make sure the condenser fan motor is running and clean out any dust back there,if the coil is clogged with dust or the condenser fan motor isn't working is what could make that strip hot.
Aug 30, 2012 | Whirlpool Refrigerators
We have a Whirlpool side by side Fridge/Freezer and the fridge side door handle is very loose and we're not sure as to how to gain access to tighten them up. Any ideas?
Try RepairClinic.com. They may have exploded views of the parts for your refrigerator. They also provide detailed step by step help making repairs. You'll need the approxomate date of manufacture, Model #, and serial #.
Feb 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water dispenser will not shut off
Hi and welcome to FixYa, I am Kelly.
Most likely the water dispense switch has failed or the actuator for the switch is bent. In either case the remedy is to replace the switch. There could be a shorted wire in the door but it would be the least probable failure.
The failed switch will be item 14 of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265471&diagram_id=127274#d127274
Here is a manual to assist you:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
See page 23 to gain access to the switches. The water dispensor switch will be on the right.
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | KitchenAid KSCS25FKSS Side by Side...
I have a side by side model number ED20TK and
start over on ice. if it over fills change valve
Feb 07, 2010 | Refrigerators
Cant locate walter filter on whirlpool model ed20tk and eckmf94.
does not have one. you have to install a filter called an in line filter behing the refrigerator
Jun 21, 2009 | Refrigerators
My refrigerator stopped making ice cubes
The water inlet valve is located in back on bottom right side. You have to remove the cardboard cover to gain access.
Mar 30, 2009 | Whirlpool ED5FTGX Side by Side...
How to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Feb 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Whirlpool Icemaker Swith has ** light
the kit number is 4389102 it has both the emitter and reciever as one part, change both in the kit
Mar 10, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
