Question about Horizon Fitness Horizon Motor T51 (treadmill)
Horizon fitness T52 treadmill speed buttons will only increase speed not decrease
We just got our treadmill back out after a few years in storage. When using, the speed will only increase when using the speed buttons... Even when trying to decrease, the speed increases.
5 Suggested Answers
SOURCE: I have a horizon fitness, Quantum II treadmill.
im having this problem too if some one could email me how to fix it @ djbense@hotmail.com
cheers
Posted on Feb 26, 2010
  • 14 Answers
SOURCE: The console display on my Horizon Fitness T63
Sounds like there is a stuck button on the console, or possibly a loose ribbon cable inside the upper console maybe?
Posted on Oct 25, 2010
AJIN G
  • 6694 Answers
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
Posted on Dec 26, 2010
  • 84 Answers
SOURCE: Hi , I have lost my
try any magnet
Posted on Mar 11, 2011
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
Sounds like a faulty motor starter if equipped or motor it self faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Horizon Fitness Exercise & Fitness
Horizon T91 Treadmill - Key Pad Troubleshooting
correct. If the console is not responding or some buttons do but others don't the membrane needs replacement.
Apr 02, 2017 | Horizon T92 - Treadmill
Speed changes on it own
speed controller is malfunctioning
Dec 11, 2013 | Weslo Epic 10pi Rear Roller For Model...
The speed will not decrease once the treadmill is started. The speed will increase when the button is selected but will not decrease when selected. Everything else still works except the (speed down)...
Most likely the directional PCA has popped out of its housing. There is a small circuit board underneath the quick start button that works the controls. They are notorious for coming loose. If board is still in the housing then then speed down sector of the board may be bad and it will need to be replaced
Aug 13, 2013 | Precor C954i Commercial Treadmill
Life fitness 95t speeds up after confirming slower speed in cool down mode, and also pauses after touching increase button on screen. both issues are dangerous
book an engineer, sound like motor controller, loose belt could also be a issue, needs a safety check where are you based ?
Jan 27, 2013 | Life Fitness Exercise & Fitness
Horizon T52 does not work
please see the video and lube too the rollers bearing.
test too the input voltage motor, if there are voltage the motor need repair. see my personal TIPS for motor help, see the b.diagram
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Happy New Year. God bless you
Dec 31, 2012 | Horizon Fitness Exercise & Fitness
Some of the Vision Fitness t9450 treadmill incline and speed quick keys stopped working along with the manual speed and incline buttons
It sounds like you have a membrane issue. There are a number of different T9450 models and they all have slightly different consoles. You'll need your serial number to help pinpoint the parts you need. Your best bet is to go through the manufacturer (johnsonfit.com) and have them help you get the correct membrane and overlay.
Jun 08, 2017 | Dmm Vision Fitness T9500 Treadmill
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
I have a horizon fitness t51 treadmill. I weigh about 138 pounds and typically run 5 miles a day at a 2% elevation at a steady speed somewhere between 5-6 mph. It recently has developed one of two...
hi,
ok
Dec 26, 2010 | Horizon Fitness Horizon Motor T51...
Horizon Fitness Horizon Motor T51 (treadmill) Logo
15 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
