Trane error code
Trane xc 90 no call for heat error code
Hello, I am trying to wire up my new Nest thermostat coming from a Trane Weathertron. The error code E106 keeps coming up. It seems to heat the house fine. I've included pictures. Thanks in advance!
Check your settings for the stat. Be sure you have your heat set up properly. Gas/electric, tstat btings fan on in heat or equipment brings fan on???
Nov 12, 2016 | Heating & Cooling
I have a Trane heat pump that shows error 79
79 i believe is a low pressure error code. This means you are low on refrigerant
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
My volvo xc 90 sudenlly started showing me no oil pressure,stop engine I want to know what to do
get the OBD codes read to give you the fault codes , may be the oil pump has packed up , have you checked the oil level , obvious i know but have to ask
Jun 11, 2015 | Volvo XC90 Cars & Trucks
Trane xv95 converted to propane is on system lockout
There is either a problem with the ignitor or the flame sensor.
Nov 18, 2013 | Honeywell Electronic Programmable...
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
The display lights on the stereo of my 2004 xc 90 don't work. The knobs don't light up either
Dealers are expensive place to get parts, so be ready for that with your Volvo XC 90 2004. Try a local salvage yard, ebay, or some other web site to get a replacement part. Otherwise, expect about $100 to fix a broken taillight.
obd2express.co.uk
Dec 10, 2012 | 2004 Volvo XC90
Xc 90 replacement of fan -- the cost and labor???
yeah sounds right volvos can be a pain to work on
Dec 05, 2012 | Cars & Trucks
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
