Video recorder problems
Recorder seems to have locked with a video inside
Sony dvd handycam
it seems like your videos are locked
Feb 06, 2012 | Sony Handycam DCR-DVD92 DVD Camcorder
What is causing video tape to be trapped inside recorder
it is usually to do with the calibration of the tape locks, sometimes it is to do with the tension on the tape being too loose,so check the tapes are wound sufficiently and if this problem persists, have it seen to by a professional engineer.
Nov 29, 2011 | Philips DVDR3430V DVD Recorder/VCR
My remote control has broken. I am getting no response although I have changed the batteries
There are two possibilities for failure; the remote itself and the receiver in the recorder.
Many service shops have a simple device that will reveal if the remote is putting out any signal at all. If it does, the output is probably correct; they don't often fail by screwing up the coded infra-red signal.
If the remote seems to be working, then your problem lies with the receiving end inside the recorder.
Oct 24, 2009 | Evesham PVR160 Freeview 10-Hours Video...
R15 DVR locked in record
2 months ago my R15-500 stopped working. The "Record"(yellow) light was dim on the front of the DVR and a lightly audible clicking noise could be heard from inside the DVR. So I searched the internet and found this FIXYA site. I disassembled the DVR as instructed and removed the power board. Sure enough the Capacitors were bulging on top. I replaced all of the capacitors on the power supply output, I think 6 altogether. I reassembled the unit and it worked great.
Jul 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Green Video Light constantly on. will not operate at all
Hello, I have the same problem, did you manage to fix this problem? Thank you
Apr 14, 2009 | JVC DRM10 DVD Recorder
Philips DVD hard drive recorder HDRW720 locks up
Do you have a disc locked up inside?
I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Mar 26, 2009 | Philips HDRW720 DVD Recorder
XH-A1 Stuck in Lock Mode?
Take the camcorder apart then press the button inside it because it seems there is a plastic peice broken on the button.
Apr 10, 2008 | Canon XH A1 Mini DV Digital Camcorder
DS-400 DIGITAL VOICE RECORDER
Had same problem. Found online handbook for DS-4000 and page 37 pointed way.
Press menu button on the handset.Go to sub menu. Page 37 of online handbook suggests you can lock and unlock from this but I used the format icon on the submenu to reformat the card. Seems to be working fine now.
Feb 14, 2008 | Olympus DS-4000 Digital Voice Recorder
Creating YesDVD on GoVideo VR2940
i have found if there is a tracking problem with a tape in a section it will confuse or "lock up" the unit - unplug from the wall for 10sec and retry.
Nov 14, 2007 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
