Question about GPS
Sky com help
Doesnt record
How do I record from my sky box onto disc
go and download the instr.manual to www.fitness.manualsonline.com or www.retrevo.com or manualsfactory.com
God bless you
Jul 20, 2012 | Toshiba DVR660 DVD Recorder/VCR
I have a toshiba rdxv60kb dvd recorder,,and can;t tune the programes into my sky box.
I have a toshiba Hdd & DVD / Video Recorder However I can not get it to work with my Sky setr up If I set thimer recording it does not work when I turn it on it will only work pn channels that are not from sky it will not instant record nor will it record programmes prerecoreded of sky HDD it will record everthing other than what I want.
My E-Mail Addres Is fj.gadkey_1@sky .com
My Home hone is uk 01527 545284
Nov 08, 2010 | Toshiba DVR660 DVD Recorder/VCR
Hello! I have just purchased a LG DRT389H DVD recorder as I want to copy the programmes that I hv on my sky+ box. I have followed every instruction in the book but for some reason am just unable to do so....
Connect the sky box to the dvd with a scart lead,plug it into av2 on the dvd.When you want to record from the sky,select av2 on the dvd as your record channel.Check that the scart is fully in on the tv and the sky for sound problem.
Nov 15, 2009 | Televison & Video
Cannot tune -in my panasonic vcr. it plays tapes but will not record. I have wired together the tv, sky box and vcr in what seems the obvious way (and every alternative) but no joy so far. can you help?
The main aerial goes into the vcr,a fly lead then comes out of the vcr into the tv,a scart lead from av1 on the vcr into the tv.If you want to record from sky and the vcr has two scart sockets then connect a scart lead from the sky into av2 on the vcr,when you record from sky you select av2 on the vcr as your record channel
Sep 24, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
How do i connect a dvd recorder. to my sky box and t.v
Take the main aerial into the dvd,then a flylead out of the dvd into the tv.Connect a scart lead into av1 onthe dvd and then into the tv.If you want to rec from sky connect scart lead from sky into av2 on the dvd,when you want to record select av2 on the dvd as this is the channel to record the sky on.Hope this helps
Sep 08, 2009 | Televison & Video
I have just bought a samsung lcd tv with 1 scart socket. But I have a satellite box and an hdd recorder but I dont know how to connect it all up. Could anyone help. Thank you
The Sky box should connect to the TV using it's TV Scart output.
The HDD recorder then connects to the SKY via the other Scart.
When you turn the HDD recorder on, the SKY box will automatically switch.
You need to put your normal antenna into the HDD recorder and tune it in.
When the Sky is off, you can use the HDD recorder for playback, you can also switch between the 2 when it is on with the Sky remote.
Sep 05, 2009 | Samsung Televison & Video
I AM LOOKIN FOR A SETTING UP DIAGRAM SO THAT I CAN RECORD FROM SKY TV, CAN U HELP?
your best way is to use scart cables 1 from sky to video/dvd recorder other from sky to tv your sky box should have 2 scart sockets
May 13, 2009 | Lite On Lite-On LVW-5045 DVD Recorder with...
Sky+ DVD Recorder Tuning
You need to connect up the Sky+ to your recorder via scart. This will eliminate poor picture quality. The Sky box will be on ext1 on your recorder or something like that
Oct 12, 2008 | Televison & Video
Watching another channel while recording
Hi there! Sorry but you can't unless you have My Sky/HD recorder. The sky decoder is simply a one channel watch decoder. You can only record a sky channel and watch the channels normally provided via your VHF and UHF aerials connected to the decoder or vice versa.
My Sky fixes that although you cannot record to a dvd disc on this thing and the privilege comes at a price of course!
Aug 03, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
GPS Logo
193 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
