Question about Refrigerators
I have a whirlpool fridge model # gb2fhdxws08 bottom freezer is leaking water on the floor about every 24 hours and some ice build up on bottom of freezer is this to do with my self defrost ?
Tech007
  • 63 Answers
SOURCE: water in bottom of fridge
THE DRIAN HOLE IS CLOGGED ITS IN FREZZOR IN THE BACK BEHIND THE BACK PANEL BUT YOU CAN LOOK UNDER THE FRIDGE AND FIND THE OTHER END OF THE DRIAN HOSE BLOW AIR TROUGH IT TO CLEAN IT OUT MAKE SURE THE FRIDG IS OFF FOR A DAY, OPEN FREEZOR DOOR TO MELT ICE IN DRIAN HOLE AND HOSE AIR PRESSOR MAY NOT BLOW THE ICE BLOCKAGE OUT DEFROST FOR A DAY THEN IT WILL CLEAN UP NICE
Posted on Aug 30, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
Maytag317
  • 1136 Answers
SOURCE: model 501-64822 is a self-defrosting Kenmore that
Hi, Look that model # up again please. The problem you are having is the defrost drain is plugged. Remove the rear panel inside the freezer and melt all the ice. Locate the drain hole and flush it out with hot water. Some modles need an after market drain heater kit. Get me the model # and I can look this up for you.
Vic
Posted on Jul 04, 2009
Richie_asg1
  • 1036 Answers
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Posted on Sep 08, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Water gathers in bottom of freezer and thaws out and runs on floor. model LRFC25750TT
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | LG LRFC-21755ST Bottom Freezer...
Whirlpool refrigerator (top freezer) is leaking into bottom of fridge. What can it be?
Hi, read about your problem. What's happening is your drain in the freezer compartment in the back behind wall is plugged. Defrost water then builds up under freezer floor and freezes. To fix, remove back wall. Also the floor needs to be opened up. Use a blow dryer to clear ice out of drain, in the trough, and under the floor. Hope this helps
Jan 18, 2011 | Whirlpool Refrigerators
I have a GE profile performer fridge ,with freezer on bottom there is water and ice build up at back of compartment, almost looks like a drain usually leaks out on floor in front of freezer compartment.
drain is frozen up. unplug and leave bottom door open for 24 hours and may be ok. Only alternative is to remove the bottom of the fresh food section and de-ice with blow dryer. If it does it again then the Styrofoam between frig and freezer must be replaced.
Oct 27, 2010 | Refrigerators
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Whirlpool fridge model # ed2fhgxkt04, ser # sm4434895. I am getting ice buildup in bottem of freezer. no ice on food or sides of freezer. where is defrost drain located to clear and or defrost it?
First off, if you get in a hurry, you can cause serious damage.
The machine must be unplugged, and allowed to completely defrost.
24 hours would be considered normal, but you can quicken that up some by placing a floor fan in front of the freezer compartment with the freezer door left open.
You can access the drain hose by removing the rear access panel.
Service techs then use compressed air connected to a hose and insert it in the end of the drain hose, and, BLOW AIR THRU IT GENTLY.
2 causes for this problem. one, the drain was in fact plugged up. Two, if the machine has an icemaker, the fill hose from the water valve to the ice maker is leaking, causing water to leak and then freeze in the bottom of the freezer.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in bottom of fridge
Aug 29, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
