Question about Lands Phones
Base not charging handset - Lands Phones
snakehead
  • 1074 Answers
SOURCE: Base won't charge handset
the base of your handset needs to be repair take it to a tech
Posted on Apr 04, 2007
  • 146 Answers
SOURCE: Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
Posted on Jan 16, 2008
  • 38 Answers
SOURCE: base does not charge handset
If all 3 handsets fail to charge on the base unit that leads one to the conclusion that the charger with-in the base unit has gone bad and I really don't know of any fix. Thank You. Jerry
Posted on Feb 11, 2008
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
SOURCE: ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Posted on Apr 14, 2008
Battery charged displaye no link to base
Many models of cordless phones that have multiple handsets require the handset to be cradled in the base unit for identification and link. As long as the handset maintains a charge, the identification remains valid. If you remove the battery or drain the handset to a point where the handset ID is lost, then you may have to re-cradle the handset in the base unit to reestablish link.
Mar 19, 2015 | Lands Phones
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 25, 2011 | AT&T E5640 Phone
I have put new batteries in my diverse 4016 phone on the base but it will not charge.can you please sugest what the problem maybe' thanking vou ...
It looks that the handset is not charging from the base unit: if you have a multimeter you can check that you have a voltage slightly higher than your battery pack voltage on the base unit. Make sure the contacts are clean and If you have no reading, then the charger on the base unit is very likely defective.
If you do not have a multimeter, check and clean the (two) contacts on your handset and base unit to ensure proper electrical contact and that you see the charging indicator displayed on both the base and the handset.
If that does not work, to assess if the issue is with the handset, swap the phones from the base and the stand-alone charging station and repeat the test: if it works, swap the batteries between the handset to see if it makes any difference. If it works, then the issue might be with the original base unit handset as you have now 'tested' the new battery on the alternative handset. To summarize, it is a test by trial and error swapping.
Hope the information is of assistance.
Sep 26, 2010 | GE 27851FE2 Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Mar 12, 2008 | Panasonic KX-TG5632 Phone
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
Base does not charge handset
Dec 28, 2007 | Uniden Cordless Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Apr 04, 2007 | GE 26938GE1 Cordless Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
