Question about Plumbing
Glacier bay faucets owners manual
825 series what is allen screw size in handle so i can remove handle and take apart to clean and service tap
  • 11 Answers
SOURCE: Moen Villeta 2 handle bathroom faucet, need to disassemble
hold the handle and twist the piece below that doesnt turn, anti-clockwise, it should unsrew and the handle should pull off.
Posted on Feb 11, 2009
  • 68 Answers
SOURCE: glacier bay kitchen faucets with 2 handles and a sprayer
to be honest with you if there is a problem the glacier bay brand is from home depot and they are usualy around 20 to 30 dollars the replacement stems are usualy 15 to 40 depending on the part plus the hours ur gonna spend fixing it your better off with a full replacement. if replaced keep in mind you might want to replace the supliy lines to the faucet with stainless steal suply lines to ensure no leaks and if your shut offs are old dont touch them shut off your water main and drain down your house by opening all the faucets and shower valvs in your house then drain at the lowest point in the house weather it be a sink in the basement or an out side faucet once the supliy lines and faucet is in place then close all the faucets you opened and slowly turn on the water to your house slowly and this will ensure you dont have any leeks from your shutoffs good luck  your friendly plumber
Posted on Apr 12, 2009
  • 439 Answers
SOURCE: how do I take off handle
Yes, it will be a small allen key that needs to be loosened before you can remove the handle.
Posted on Jun 24, 2009
  • 235 Answers
SOURCE: The faucet handle has become stiff to turn off and
The handle has build up in it but should come off eventually. Sounds like a dry o-ring seal. You can purchase a kit for your model without having to replace the whole unit.
Posted on Jul 05, 2009
  • 129 Answers
SOURCE: Our glacier bay two handle faucet (sink in half
If you the teapot style faucet directly on top of handle, the little round cap should come off so you can see the screw that lets you remove handle. The other style will have set screws on the outside of either handle. You will need a allen wrench.
Posted on Nov 05, 2009
How do I change the washer on faucet
1. turn off water under sink 1st both of them
2.remove the handle screw on top or allen screw under bottom of handle pry off
3.crescent wrench unscrew valve remove
4.on bottom of stem unscrew remove washer{replace the "O" ring on the stem while out}
5. put back and turn on water check for leaks,
Hope this helps let me know Mike
Jan 03, 2016 | Globe Union Glacier Bay 8 In Double Handle...
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
How to fix a Glacier Bay Bathroom Faucet/ Leonardo
Usually they have a small screw, but its hidden under a cap. Look at the handles you should see a small plastic cap sometimes colored red and blue for hot/cold. Using tip of small knife pop out the cap/plug. The screw holding the handle on is in there.
Mar 20, 2015 | Plumbing
How can you remove a 7560w spray head?
  • Take out the plug button on the front side of the faucet handle and loosen the set screw with your Allen wrench, then pull off the handle. Remove the domed cap underneath the handle by unscrewing it.
  • Take off the entire spout by removing the mounting hardware under the base and lifting the spout up and off the faucet. The hose will be attached underneath the counter. Once you unscrew the connector, the spray head can be removed.
Sep 09, 2014 | Moen 7560W Extensa Glacier Lever Handle...
Glacier bay manual
Look for a small cap on the handle....may be coloured...pry it off
to expose the retaining screw or Allen key.
Regards,
Dennis
Aug 12, 2014 | Plumbing
Base of faucet leaks- cannot remove set screw at handle American Standard Elite kitchen faucet series 4453
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Feb 25, 2011 | American Standard Kitchen Faucet 6310 020...
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Our glacier bay two handle faucet (sink in half bath) leaks from the hot water handle. We've had the hot water turned off to avoid the problem. Now that cooler weather is coming we'd like to wash our...
Nov 04, 2009 | Plumbing
Handle Removal on Chateau Style Bathroom Taps
the handle removal is a metric allen wrench some of the cartridge replacements come with an allen head wrench
I always plug the drains and completely remove the allen head screw then the handle comes off
Sometimes you have to pry it gently or take a hammer wrap a towel around the handle where it meets tthe cartridge base and tap up under the handle lightly and it comes out
God Luck
Nov 28, 2008 | Moen Chateau, Two-Handle Garden Tub Faucet...
Plumbing Logo
168 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
