Question about Toshiba Televison & Video
Television stays in standby and won't switch on, just a high pitched sound
My Toshiba television goes into standy mode when you switch it on but then won't power up when you press the on button on the remote, it's just a high pitched sound. If I turn the television off for a whole day it's okay the next day though. However, give it a couple of hours and it won't switch on again
  • Toshiba Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
Television will not stay on. Runs for 5 seconds then goes into standby mode.
Modern Flat Panel Televisions these days are really just computers inside. The Switch Mode power supply has the ability to sense faults & over current draw. So... there really isn't much the average person can do to fix an electronic problem.
The usual problem is overheating, bad connector problems & electrolytic capacitors leaking or popping. If you don't have the skills to open & look for problems then you will have to take it to a tv electronics guy.
Cheers
Feb 21, 2015 | Panasonic Televison & Video
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Feb 18, 2014 | Samsung HLP5067W Television
I have a 52in ilo flat screen television that just stopped turning on. It stays in standby mode. It use to come on and periotically would stay in standby mode. It is now stuck in standby mode.
Check and replace its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 17, 2014 | iLO 3200 32 in. LCD Television
Picture ok but loss of sound with high pitched buzz
Power board have problems.Take the tv aparts put some super glues on all around the transformers.Will help lower the buzz alots or stop it completely.
Feb 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
When switching off the television with the on/off switch the red
That just lets you know that it is in standby mode..
Feb 01, 2009 | Samsung TXJ3678 36" TV
Problem with NEC PlasmaSync 42MP1 42 inch - goes to standby w/no picture
Has anyone figured this issue out? Im really hurting without a tv,
Jun 21, 2008 | NEC PlasmaSync 42MP1 42 in. Television
NEC PLASMA SYNC 42MP2 STANDY BY MODE?
According to the manual for "POWER/STANDBY indicator is blinking in red":
  • "The temperature inside the main unit has become too high and has activated the protector."
  • "Promptly switch off the power of the main unit ans wait until the internal temperature drops."
  • "If the monitor becomes too hot, the overheat protector will be activated and the monitor will be turned off. If this happens, turn off the power to the monitor and unplug the power cord. If the room where the monitor is installed is particularly hot, move the monitor to a cooler location and wait for the monitor to cool for 60 minutes."
Feb 04, 2008 | NEC PlasmaSync 42MP3 42 in. Television
My hitachi has sound but no picture
sounds like defective pwr board, you will need to do many checks to determine for sure.
Dec 26, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
246 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
