Question about Directv D10 DTV Receiver
Autotune not working - Directv D10 DTV Receiver
    New Friend:
My pc has windows 8 pro.and wen I install autotune 5 to run it with pto tools le 8it does not work
Posted on Mar 03, 2015
Re auto tuned tv now have no channel 7 at all have booster live in Lake Macquarie Nsw
Autotuning did not detect channel 7. You may be able to add channel 7 manually or fiddle around (the technical term) until you can get autotuning to find it.
Apr 11, 2018 | Televison & Video
Tip
How to speed up the upload speed of web pages in Windows Vista
f6049a7.jpg As many of you have noticed, browsing and download speed web are quite slow with Windows Vista. Today’s tip perhaps will help you to increase the browsing and download speed in Windows Vista.
There are two ways you can do to increase your internet speed.
If you want to try this out, follow the steps below for the first method:
1. Open Internet Explorer.
2. Click on Tools and then select Internet Options.
3. Click on Advanced tab.
4. From the settings, scroll all the way to the bottom.
5. Check the box of Use SSL 2.0 (Secure Sockets Layer) and uncheck the box of Use TLS 1.0 (Transport Layer Security).
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Continue with following steps for the second method (This method might not work well):
By default, the TCP autotuning is enabled in Windows Vista. Many websites do not respond well with this feature. So these sites are loaded slowly.
To disable TCP autotuning feature,
1. Firstly open the Run option from the Start menu.
2. Type cmd in the box of Run option.
3. A command prompt will show up, type netsh interface tcp set global autotuninglevel= disabled in it and then hit enter.
4. The TCP autotuning should be disabled now. Close the command prompt and restart your computer.
To restore or re-enable the TCP autotuning feature,
1. Type cmd to the Run option and then type netsh interface tcp set global autotuninglevel= normal in the command prompt. Press enter, close it and then restart your computer.
The TCP autotuning should be enabled now.
on Jun 15, 2010 | Computers & Internet
During autotuning storing of chanels problem.
Main system control memory IC fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 04, 2015 | Aiwa Televison & Video
I have a windows 7 pc.i downloaded the autotune evo 6.I installed it on my pc...it installed correctly..but the problem is that there is no option to uninstall it...i tried really hard but i couldnt...
When an application/program is installed, Windows does more than create a new folder on the hard drive. It also writes data about the program to a 'registry', that keeps track of many system settings, including installed programs. Your best bet at fixing this problem would be as follows:
- Download Ccleaner from here: http://www.piriform.com/ccleaner/download/portable Extract the .zip file and run 'ccleaner.exe'. Navigate to the 'registry' tab, and click 'Scan for Issues'. A list of potential problems with the registry will be generated. One of the things this will look for is any registry entries that link to folders that do not exist (like the one you deleted). After the scan has finished, click "Fix selected issues..." If you are prompted to back up the registry, you may do so, but it is not necessary. Restart the computer and try to install AutoTune.
- If that did not work, open the control panel (Start -> Control Panel, or type 'control panel' in the start menu search box) and navigate to 'Add/Remove Programs'. After the list has populated, look for your AutoTune program in the list. Select it, and you will see an option for 'uninstall'. Try to uninstall it. If you get a message saying that the program cannot be found, and you are asked to remove it from the list, say 'yes'. Reboot and try to install AutoTune.
- If you still cannot install AutoTune, download and install Revo Uninstaller, found here: http://www.softpedia.com/progDownload/Revo-Uninstaller-Download-74235.html This will deeply scan your system for any programs that are installed or that have left remnants of themselves behind. Try to uninstall AutoTune from Revo Uninstaller, reboot, and try to install AutoTune.
Mar 21, 2011 | Antares AutoTune EFX Full Version for PC...
Hi there I just bought an LG LCD HDTV 720 last night. I got it home, we turned it on and it was working fine. I turned it off and went out, came back and turned it on again. I started setting up the...
The television is not working at all? Have you tried to operate it manually? Are the batteries in the remote new? Have you rechecked all of your connections? Did it pop a breaker or a circuit strip?
If you have checked ll of these things, and they are okay, then you need to carefully box the TV back up and take it along with your receipt back to the store where you purchased it and tell them it does not work. Period. Don't go for a restocking fee or them tinkering with it. I have learned that these LCD TV are sometimes bad from the getgo, and those are problems no one needs.
You should be able to autotune or use any of the features on the TV, so don't be blaming yourself for something that should work.
Dec 21, 2010 | LG 32LG30 32 in. LCD HDTV
I am in Afghanistan, Kabul Area. I have an ALT2260M Avol tv. when I use the autotune for channels, All I get are the local channels. We are hooked into the AFN Network cable and it does not pull those...
try going into the autotune then select us then cable select the auto acan then change from auto to irc or std then scan should do the trick.
Dec 06, 2010 | Televison & Video
Autotuner problem with Kenwood TS=450SAT
Sorry, I did not realize that this was a fix-it-for-hire place. I thought it was a place for free advice
I will take my problem elsewhere.
73'
WB9RWW
Jan 03, 2009 | Radio Communications
AutoTunes installation error. Help?
Is it a legit copy of autotunes? That sounds like a corrupted install file or a corrupted copy of windows.
Feb 02, 2018 | Antares Auto-Tune 4 TDM Production Suite
Directv D10 DTV Receiver Logo
107 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
