Question about Kenmore 24032\24036 Top Load Washer
Will not fill with water
I have a kenmore washer when turned on water comes in but it will not fill it just keeps running.
    President:
  • 1,136 Answers
Hi, First thing to check is the drain. Make sure your drain hose is higher then the water level and make sure, if you have it draing into a sump that the end of the hose is not laying in the water. I hope this helps. Please let me know,
Thanks
Vic
Posted on May 20, 2009
My kenmore 600 washer will just keep running water and won't fill up, what is the problem
check the drain hose at the back
it has to be higher than the tub of the washing machine or it is a case of water in water out ----no pump required
Sep 30, 2016 | Kenmore Washing Machines
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore top load washer keeps filling, watere
the fill valve is bad or there is a hole in the tubing that attaches to it, this tube goes from the pressure switch to a bulb on the side of the tub only air pressure goes through this tube one small mouse bite and it is damaged
Jul 06, 2009 | Kenmore Washing Machines
Not filling to wash
The drain hose is very long. Check to make sure it is not pushed too far down into to drain in wall. If so pull it out as to prevent washer for syphoning water.
May 20, 2009 | Kenmore HE2 Plus Front Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series extra capacity
This could be from a few things. First test. Turn on the washer to fill it up about 3/4 the way. Now turn it back off. Does the water stop? No? You probably have a bad water valve. Replace it. Yes? Listen for the sounds of running water or look for water on the floor. Do you see/ hear this? Yes? Your pressure hose has probably come off, reattach it. If it does turn off and there is not further sounds or leaking water, you probably need to replace your pressure switch.
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
70 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
