Question about Exercise & Fitness
Proform 920 treadmill
Rubber coating on front roller is breaking apart. Is there a replacement part
  • 64 Answers
SOURCE: I lost my owners manual for my Proform 585 treadmill
Iconfitness.com
Posted on Jun 08, 2009
  • 95 Answers
SOURCE: My husband took apart the bottom of our proform
The wire grounds the roller to the frame,the roller adjuster screw passes through it and it sets loosely on the screw
Posted on Aug 14, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
maxtreadmill
  • 832 Answers
SOURCE: treadmill front roller has a rubber sleever that
That front roller's rubber sleeve by all rights should not be moving any which way. This mean the roller will have to be replaced call iconfitness @1-888-999-3756 and order a new up-graded front roller .
Posted on May 10, 2010
maxtreadmill
  • 832 Answers
SOURCE: front rollerhas is rubber coated and the rubber
This is a common problem with front roller that utilizes a coating that you described. Treadmill Doctor.com has these sleeves for icon fitness units they may work for your unit give them a shout they are in the state of Tennessee USA.
Posted on Aug 14, 2010
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
How to change belt on proform 920 treadmill
see the video attached and proceed according. God bless you
Nov 17, 2012 | Exercise & Fitness
Proform 730 treadmill,rusted screws won't remove to replace walking belt
Use WD40. Or go to a nearby hardware store an purchase a rust remover. Aply either one and wait for a bit. Then remove screws.
May 06, 2012 | Proform Exercise & Fitness
I have a PROFORM CX 500 at my home. It used to work fine but now there is a strange striking sound coming out of the front chamber when I run it at a spead 6 km/h or above. And with the sound you can feel...
You must LUBE the roller bearing front and back with WD-40 very well. .
2) Examine the drive belt motor, if are very tight, must be deflection 1/8" other wise the ball bearing of motor are very tight.Tight very well the bolt of motor.
3) Run again, if the problem persist, the Rollers are Faulty. Replace.
Treadmill Repair worn belt roller bearings
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 21, 2017 | Proform Crosswalk 500 Treadmill
Front rollerhas is rubber coated and the rubber has started to break up ,model is cyclone sx 9.0 max pro
Aug 13, 2010 | Cyclone Folding Treadmill
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
I have a 1992 Proform CrossWalk Dual Motion Cross Trainer. Motor still works great. There is rubber covering the roller under the moving piece. It has come off on the right side. Can this be replaced?
Really, I have had my crosswalk for over 20 years. I can't complain. I am passing it on to my son and getting a NEW Proform treadmill. Their longevity has sold me.....
Need to replace treadmill belt
Belt replacement is not a small task. If you are not mechanically incline with basic tools, find a professional. With the belt should be general instruction on how to replace belt. Side or straddle covers will have to come off, then front and rear rollers. Pay close attention to how it comes apart because you will have to put it all back together.
Jul 20, 2009 | Proform 325 Treadmill Walking Belt
Exercise & Fitness Logo
13 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
