Question about GE WPGT9360EPL Top Load Washer
SERVICE MODE Hey all Hope someone can help here.... Working on this Harmony washer and Message says error has been detected with this unit call for service Do i clear this fault by entering service diagostics???? What is the Key dance for diagnostics?? Thanks for help here
  • 3 more comments
  • joey  shearer
    joey shearer Oct 20, 2007
    amasuperbike@comcast.net
    can you give me the manual???
  • joey  shearer
    thanks again
  • joey  shearer
    joey shearer Oct 21, 2007
    I think we are fine i work for a GE authorized company and had factory training on this machine but the instructor from GE didnt have enough manuals for everyone on the harmony, and lo and behold i finally worked on 2 machines. Have you worked on this machine very often?? I unlocked the control finally after replacing the entire bearing/mechanical assy which includes the clutch coupler and the machine now seems to be somehow locking the infuser and the basket during infuser wash and preventing either from moving and i can hear the inverter trying to turn the motor but no movement. Its also hard to command the clutch shifter motor from locked to unlocked since ,i believe, there is no test for this in diagnostics, I have seen it move so I know the motor is ok. but you never really know what the control is comanding.
  • joey  shearer
    joey shearer Oct 28, 2007
    Been so busy lately havent had any time to work on it lately. I plan to do more tests on the clutch coupler and see why its binding in infuser wash. Thanks again for the job aid on it.
  • joey  shearer
    joey shearer Nov 07, 2007
    Hey thanks again for the help with the Harmony washer. I got a service call on a PSH dual evap Arctica SxS and only have the manual for the single evap PSS and GSS models. If you have this manual would you mind shooting it to my email?? Thanks in advance
  • 290 Answers
From the manual I have
1. Press the power pad to turn on
    press home pad to ensure home screen is displayed
2. Press the help pad. the main help screen is displayed.
3. Press the help and start stop pads for 3 sec simultainiously.
    The factory test screen is displayed.
4. Press test load on the screen.
5. The contrast screen is displayed. Press the start/stop pad once to cycle through the screen
6. press start/stop pad. The test load screen is displayed.
More to come... I will try to copy and paste what it says. I can try to send a copy of the pdf if you give an email.
Posted on Oct 19, 2007
  • 11 more comments
  • Michael  Lindley
    Michael Lindley Oct 20, 2007
    Hold on a minute. That is factory test mode. I just found field test mode. Will try to get it into comments.
  • Michael  Lindley
    Overview
    The washer control has a field service mode that
    can be accessed by the service technician in
    order to give critical information on the status of
    various components of the washer. This mode will
    aid the service technician in quickly identifying
    failed or improper operation of components and
    systems.
    The service mode does not use error codes to
    identify problems. Instead, the LCD screen
    displays a list of components or systems to be
    checked if a problem is detected.
    To enter the service mode:
    Note: Once the service mode is entered, all
    membrane keypanel buttons are disabled.
    1. Press the POWER key to turn the washer on.
    a. If the washer is on and the HOME screen
    is displayed, proceed to step 2. If the
    home screen is not displayed, press
    HOME on the keypanel.
    TROUBLE SHOOTER
    MACHINE
    PREFERENCES
    HOME SCREEN
    HELP
    BY COLOR BY GARMENT
    TOUCH TO SELECT WASH CYCLE
    BY
    FABRIC
    SPECIAL
    CYCLES
    STAIN
    INSPECTOR
    2. Press HELP. The main help screen is
    displayed.
  • Michael  Lindley
    3. Press and hold MY CYCLES and BACK
    simultaneously for 3 seconds:
    • The control will display any recorded
    errors. If no errors have been recorded,
    press EXIT to return to the HOME screen.
  • Michael  Lindley
    • A MORE icon will be displayed on the LCD
    screen if additional problems have been
    recorded. Press MORE to list additional
    errors.
    4. If errors have been recorded, use the error
    chart in the troubleshooting section for proper
    diagnostic procedures.
    • Use the BACK pad on the keypanel
    membrane to scroll back through the list. If
    MORE is not displayed then there are no
    additional errors.
    SERVICE MODE DIAGNOSTICS
    WATER IS NOT DISPENSING INTO UNIT
    PROPERLY.
    CHECK WATER LINE CONNECTIONS,
    WATER VALVES, AND DETERGENT
    / BLEACH / ADDITIVE DISPENSERS,
    PRESSURE SENSOR SYSTEM.
    REMEMBER TO ALWAYS UNPLUG UNIT
    PRIOR TO ANY SERVICING
    EXIT MORE
    PROPERLY.
    EXIT
  • Michael  Lindley
    ATTENTION
    IN ORDER TO EXIT THE SERVICE MODE
    THE UNIT MUST BE UNPLUGGED AND
    SERVICED. THE UNIT WILL
    AUTOMATICALLY RUN A SETUP POUTINE
    AND SELF-DIAGNOSTICS UPON BEING
    PLUGGED BACK IN.
    CONGRATULATIONS ON THE
    PURCHASE OF YOUR NEW GE
    PROFILE WASHER!
    A BRIEF SELF DIAGNOSTIC
    WILL NOW BE RUN ON YOUR
    WASHER. THIS MAY TAKE UP
    TO 5 MINUTES
    OK
    Note: Pressing exit clears all error messages and
    activates the setup mode program.
    b. Disconnect power and make necessary
    repairs.
    c. After the problem has been identified in
    service mode and repairs have been
    made, the unit prompts the service
    technician to run a setup/self diagnostic
    check. The self diagnostic check consists
    of a series of system tests to ensure the
    washer is operating correctly. Follow the
    on-screen instructions.
    5. If errors have been recorded, the following
    steps MUST be performed.
    a. Make a note of the listed errors. Press
    EXIT, the screen prompts you to unplug
    the washer before servicing.
  • Michael  Lindley
    It is easier to understand reading it from the manual than from the comments. There are several pages of diagnostic checks and tests.
  • Michael  Lindley
    PROFILE WASHER!
    TO 5 MINUTES
    OK
    repairs.
    List of self diagnostic checks:
    • Lid
    • Touch Screen
    • Beeper
    • Keypanel Buttons
    • Sensors
    • Water System
    • Drive System
    • Serial Communication Link
  • Michael  Lindley
    Just sent it. 10:39 cst. Let me know if it how it comes out.
  • Michael  Lindley
    Hope you got it. It took 30 min to send.
  • Michael  Lindley
    Michael Lindley Oct 21, 2007
    No problem. I would do the same if you came by the shop and needed to look at a manual for one of your customers machines. I don't know if I broke any copyright laws, but we can keep it between us.
  • Michael  Lindley
    I have only had one call on this machine and it was to show a lady how to select her wash cycles. I have never been into it mechanicaly except for the class we went to and I remember little of that. I will look at the manual and see if I can come up with anything that may help.
  • Michael  Lindley
    Look at page 36 of the manual about how the clutch works. It tells how to check the clutch motor. It seems that you should be able to check the voltage at the board when it changes position to see what the board is doing(page 22). I am leaning toward a mechanical problem somewhere. The board is telling it to disengage but something is keeping the coupler from dropping out. Have you tried raising and lowering the coupler shaft by hand to see how it feels?
    You could unplug the clutch from the control and use a jumper wire to power the clutch and see if the shifter motor is binding somehow. Though I am sure this is not a factory authorized diagnostic check I don't see why it wouldn't work.
    I think I would check the voltage and ohm out the shifter motor. If they are ok I bet it is a mechanical problem with the shifter or shaft.
  • Michael  Lindley
    Michael Lindley Oct 24, 2007
    Have you figured out the washer yet?
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
Stuck on "problem detected" screen
Hi deejay961...You may want to begin with the following procedures. Please update your post with your results, and if needed, we can progress until we correct your issue....good luck my friend...chris The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature. "A problem has been detected with this unit" will be displayed on the screen. The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control. Solution: 1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT. 2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in. 3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 23, 2007 | GE WPGT9360EPL Top Load Washer
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Solution:
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Wont run
Aug 19, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge profile notice: a problem has been detected with this unit
hello: I have a its a GE PROFILE WPGT9350 washer and i have that pop up when i push power button what can i do if you can help this missg "Notice A problem has been detected with this unit if you can tell me how to get to Service Mode Diagnostics" thanks my email is mnunocortes@hotmail.com Actually I have tried unplugging it and letting it rest and plugging it back in, same message. Thanks anything can help
Feb 20, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
A problem has been detected with this unit i need know how to enter my Service Mode Diagnostics
I'll email you a few pages out of a service manual for a WPGT9360 (closest I could find to your model number) hope this helps.
Nov 12, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE PROFILE WASHER M# WPGT9350COPL
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
let me know what it tell you I can help...
Sep 01, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
WASHERS WILL START
GE Profile Harmony
3 press HELP
Let me know what the errors are I can help..
Mar 16, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
"NOTICE A PROBLEM HAS BEEN DETECTED WITH THIS UNIT"
DW, Press the power key to turn the washer on. If the washer is on and the Home screen is displayed, press help. If the home screen is not displayed press home then help. Then press my cycles and back together for 3 seconds. The control will display any recorded errors. A more icon will appear in the display if more than one error was recorded. Press the more icon to list any additional errors. Use the back keypad to scroll through them. Make note of all errors and post back. We'll try to help you with the problem. Catriver
Jan 21, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE WPGT9360EPL Top Load Washer Logo
258 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
