Question about Logitech S 510 (967555) (DH967555) Keyboard and Mouse
Setpoint drivers - Logitech S 510 (967555) (DH967555) Keyboard and Mouse
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Logitech setpoint broken on Windows 7 64 bit
Sometimes the smart installer, which is the default download on logitech's site and probably what was included on the driver cd, is corrupt and you need to use the dedicated 64 bit installer for setpoint.
Try this download to fix your problem: http://www.logitech.com/pub/techsupport/mouse/setpoint620_x64.exe
Hope this helps, Robert
May 07, 2011 | Computers & Internet
Windows 7 64 bit, cant install Logitech Wireless Keyboard K340. Cannot find driver for unifying receiver. - All windows updates - SetPoint installed
Download driver files:
Click the link below:
http://www.logitech.com/en-roeu/434/6007?section=downloads&osid=14
* select windows 7
*select file --- SetPoint 64-bit
* click download software.
* install the software.
Nov 02, 2010 | Computers & Internet
Can't install CD for wireless keyboard. Need
Hello!
Usually when I install drivers for hardware I never use the CD that ships with the product. By the time the product has shipped, CD's that contain software for the product are usually outdated since hardware manufacturers are constantly updating software around the time of release and for awhile afterwords. Because of this, I like to go straight to the manufacturer website and download the absolute latest software/drivers for the hardware in question.
Here's a link below to both the 32-bit and 64-bit versions of the Windows Vista software for SetPoint. Depending on what version of Windows Vista you're running [32 or 64], choose the appropriate one and try installing that. If that doesn't work, visit Logitech's Support Website, choose your product, and download the appropriate drivers.
Logitech SetPoint 32-bit
Logitech SetPoint 64-bit
Oct 17, 2009 | Microsoft Windows Vista Home Premium with...
I can not install my logitech ex100 cordless mouse nand keyboard
have you tryed downloading the latest setpoint software? or tryed installing it in safemode? those might help
Nov 14, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Cannot get laptop to recognize logitech optical mouse
systemdude, you can download MouseWare HERE. It does not use SetPoint software. The picture of the mouse may not match your mouse, but its the same software.
anovice, you can download the SetPoint4.40 software for your LX7 mouse HERE.
neri59, you can download the driver for your mouse HERE
Cheers!
Mar 21, 2008 | Computers & Internet
Mouse not working
First try uninstalling the Setpoint software. Xp should have a native driver for your mouse. If that does not work check to see (at the Setpoint website) if they have an undated driver. Download and do it again. You might also want to run scandisk just to make sure you do not have a cross linked file before going anything else.
Jan 08, 2008 | Logitech Cordless Desktop EX110
Error Message when trying to update SetPoint 4.00.121
GO TO SETPOINT DIRECTORY. DELETE FILES: LULNCHR.INI & LULNCHR.EXE. FILES ONLY RELATE TO AUTOMATIC UPDATE FOR NEW LOGITECH SOFTWARE. DELETING DOES NOT EFFECT FUNCTIONALITY OF SETPOINT.
Nov 03, 2007 | Logitech S 510 (967555) (DH967555)...
Logitech S 510 (967555) (DH967555) Keyboard and Mouse Logo
15 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
