Question about Locks & Locksmithing
Kwikset lock instructions
How do I reset my code?
4 Suggested Answers
SOURCE: how to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Posted on Dec 02, 2009
  • 963 Answers
SOURCE: Kwikset smartcode deadbolt. The
Let's review the programming steps, in case you are overlooking something. This information was found at this link:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Important before proceeding: 1. Verify that position #2 of the "Settings
Switch" is in the OFF position. (Refer to section 11.) 2. Work with the
door open (away from jamb) to avoid accidental lock out. 3. Make sure
the bolt of latch is in the extended (locked) position
8. Automatic - Bolt Direction Determination (Door Handing).
IMPORTANT: DO NOT SKIP THE FOLLOWING STEP.
LOCK WILL NOT BE ABLE TO OPERATE PROPERLY!
? In the steps below, the SmartCode mechanism automatically determines the "door handing" and sets the proper direction for motor to rotate.
a. Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into the interior assembly (the tabs on the pack must face out)
b. When the unit begins to operate the bolt, release the "LOCK" button.
c. Do not disturb the unit for approximately 20 seconds until the interior Green LED flashes followed by a beep. During this time the system will drive the bolt several times, will determine "door handing", store data in memory and exit. It is very important that this process is allowed to finish properly.
Proceed with programming your Usercodes per the instructions.
Finally, here is the contact number for Customer Service At Kwikset. Call them if you still have the problem.
1-800-677-5625
Posted on Aug 04, 2011
SOURCE: keypad won't work
I called customer service and the person who answered was almost rude. They do not sell the internal assembly, I would have to purchase a new lock as it is out of warranty. End of discussion. Thank you for calling and he hung up. I could not in good conscience purchase another product from them.
Posted on Dec 02, 2013
Need to reset code
Here is an excellent video of how to install, hand, and program the Smartcode 909. It includes switch controlled features of the lock:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Installation instructions:
Jul 17, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
How do I errase the code and reset a new code on my kwikset powerbolt keyless entry door look
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Jul 05, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
Need to clear codes
Go to http://www.kwikset.com/Customer-Support/How-To-Center.aspx It will give you a step by step instruction on how to reset the code for your lock.
Jun 11, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The lock is beeping. I put new batteries in and reset the code and it still beeps.
Here is a link to the installation and programming instructions for your lock:
Starting with Step 7 (battery replacement), it is very important that you follow the procedure very carefully throughout the rest of the steps.
If your problem persists, there is contact information at the bottom at the instructions sheet to enable you to pursue parts and further technical advice directly from Kwikset.
Jun 07, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
How to reset and change the code
Go to this page:
which is a PDF file of showing the installation instructions for the 909-15 lock. Starting at Step7 is how to change the battery (a really good idea at this time), followed by the programming instructions. Follow the steps carefully--very important!
Jun 05, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
We need to reset our lock with a new code
Here is a link to the installation instructions. I suggest you replace the batteries while you're doing the reprogramming:
Apr 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How do I reset my code for this lock. I bought house with this lock and there is no manual on how to reset code. Please help
This link:
Mar 07, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
I need to change the code on the lock . I just purchased a House with this lock and no instructions were left to change the code. I know other people know this code so I would feel alot safer to be able to...
Here is a link to the installation and programming instructions for kwikset Powerbolt:
Here's the main product page:
http://www.kwikset.com/Products/Categories/Electronic-Locks.aspx
Feb 23, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
I replaced the batteries. After inserting them back into the system, the lock does not operate. I have tried pushing program button 3 times and waiting 10 seconds, nothing. I removed the batteries again...
Here is a link to the complete set of installation instructions for the Kwikset 909-15:
If, after following the instructions for replacing the batteries and reprogramming the lock it still doesn't work for you, I suggest contacting Kwikset Customer Support:
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
This is a link to the customer support page:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 02, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How do i reset the codes
kwiset smart code How do i reset the codes
Oct 07, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Locks & Locksmithing Logo
66 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
