Tune sharp aquos tv model lc 19d1e bk - Televison & Video
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
bshldn
  • 736 Answers
SOURCE: Can you give me the manufacturers PIN code for
There is no manufacturer's pin code. There are discrete remote control codes. If the problem is that the television is asking for a four digit code you have to go through the steps to clear all.
Press MENU to display the MENU screen, and then press to select "Setup."
Press ^/v to select "EZ Setup." "CH Setup," "Parental CTRL" or "Reset," and the Secret number Input screen displays.
Press and hold both CH ^ and VOL + on the TV simultaneously until the message appears on the screen.
If the problem you are having is that the television will not change inputs when you press the input button or something similar you will need to complete an Industry Initialization.
Posted on Dec 24, 2010
jyackle5
  • 8197 Answers
SOURCE: Sharp LC-19D1E-BK Instruction Manual
You can get the manual on the link below.
http://www.tradenet.sharp.co.uk/files/Consumer_Electronics/LCD_Television/LC19D1EBK/LC19D1EBK133.pdf
Good Luck
Posted on Jan 01, 2011
vuduc_pham
SOURCE: Need user manual for 42"sharp aquos lcd tv
INTERNET CONNECTED
Posted on Jan 28, 2012
gopakumarg43
  • 74377 Answers
SOURCE: I forgot the parental control code Aquos Quattron TV Sharp LC-40LE835U, change the factory code, wanting to restore everything, ask me the code, and forget to the code. Note: use codes 0000,1234,3
Refer its user manual for more details. It will have the default reset code.
Posted on Mar 17, 2014
How do I tune my AQUOS GA206wjsa? Amy
Hi Amy,
The number you have there is the part number of the remote for the TV. I found the model number for the TV itself and the manual for the TV. The model number is LC-22AD1E, the manual for that is here:
http://www.sharp.co.uk/cps/rde/xbcr/documents/documents/om/11_lcd-tv/LC22AD1E_OM_GB.pdf
Hope that helps.
Jeff at Remotes.com
Apr 14, 2017 | Sharp Aquos Televison & Video
No sound from TV - Sharp TV LC-32GPIU
Check to make sure you have the speakers tuned on in the setup menu, and you are not in sap.
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Can't retune sharp aquos lcd tv
This is the best place that's near the manual you need.
They have the LC32D44E manuals, but not the "BK" at the end. I think the "BK" just means BLACK.
But, I think it will work for your TV.
Here's the link:
http://www.sharp.co.uk/page/downloaddrivermanuals#
Click on the "Sharp Europe - Manuals and Download "
Then, Operation Manuals
Then, LCD-TV
Then, put your TV model# for the search.
Apr 21, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
