Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Lots of smoke coming out of Cub Cadet 2146 muffler
I added oil since there was no reading on the stick and now I have lots of smoke coming out of the muffler, did I add too much? If so, where is the plug to drain and refill? Any help is appreciated - Pam
    Problem Solver:
  • 9 Answers
Check the dip stick to see if you over filled it.. You shouldn't have oil above the top line... If you did over fill it remove the dip stick and tilt the mower to the exhaust side to drain on the excess oil out of the dip stick tube...
If it's not over filled with oil the engine more then likely shot and it's time for a new mower..
Posted on May 21, 2009
  • Wesley Pennypacker May 21, 2009
    I'm sorry I thought you were asking about a push mower...
    Everything I said is the same for a ride on but the part about draining the oil...
    You should be able to find the drain plug somewhere on the bottom side of the engine...
Cub cadet 4621 zx390 single cyl. oil comes out of dip stick tube where is breather located
Find your carburetor assembly. you have a rubber tube coming from that to your to your oil breather. you can also look up your parts manual using the same info you gave here. Cub cadet 4621 zx390. looks like a kohler engine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 29, 2017 | Cub Cadet Garden
Why is my cub cadet xt1 blowing black smoke cleaned air filter made sure oil level is correct.still blows black smoke
Make sure that at full throttle the chock is not being used. Black smoke coming out of the exhaust of gasoline engine is a sign of a rich fuel mixture (too much fuel, not enough air). A brief puff of black smoke may be visible during hard acceleration when the fuel mixture goes momentarily rich, but under normal running conditions and idling the exhaust should be transparent. If black smoke is visible all the time and the inside of the muffler is coated with heavy black carbon deposits, it would tell you the engine has a rich fuel condition.
On engine, a rich fuel condition and black smoke can be caused by a stuck or maladjusted choke, a leaky metal or hollow plastic float inside the carburetor fuel bowl, or a fuel saturated foam plastic float, or an incorrectly adjusted float (set too low). A trestricted fuel filter may also contribute to a rich fuel mixture.
Jul 04, 2017 | Cub Cadet Garden
My cub cadet sc 100 won't start after putting it on it's side to sharpen blade.
Since you put it on its side, you most likely dumped all the oil from the crank area to the cylinder and carburetor. What you need to do is check engine oil to be sure it is full. Then take air filter off, clean the carburetor with carb cleaner. Remove spark plug, clean spark plug with carb cleaner. Pull the cord about a dozen times WITH THE SPARK Plug removed. Then install spark plug and try to start.
Feb 15, 2017 | Cub Cadet Garden
What does white smoke coming from a cub cadet lawn mower mean
Most likely the valve seals or the rings are bad and the engine is burning oil.
Oct 06, 2014 | Cub Cadet Garden
Oil drain location on cub cadet rt65
How old is it? Lots of newer small engines don't have a drain plug. You tilt it on its side and let the oil run out the oil filler hole after removing the dip stick. I put a piece of plastic shopping bag over the gas tank hole and put gas cap back on to help keep gas from coming out. Good luck.
Jul 26, 2014 | Cub Cadet RT65E - RT65E 18" 208cc Dual...
I have a cub cadet 2146 riding mower. I've changed the battery and replaced the fuses, still no power. What else could the problem be?
check the battery connections and also the earth cable if no luck their then check the fuses with a test light or similar and look for a feed to the fuses as the connections at the back of the fuses could be corroded
Nov 23, 2011 | Cub Cadet Garden
2005 Cub Cadet RZT 50 dark grey exhaust smoke upon start-up, plus some smoke when blades are engaged. Muffler gets very hot, and the engine seems to choke somewhat. The remote choke lever is opening and...
It sounds like it is very likely you have gas in the oil. This happens when the needle valve in the carburetor is leaking gas thru and into the crankcase. That will have to be repaired and the oil needs to be completely drained and refilled before running. Another thing can be done as a temp fix and that is to place a fuel (gas) shutoff in the line and turn off when not running but the oil has to be changed. Hope this helps you.
May 01, 2017 | Cub Cadet Garden
Cub cadet 1050 changed oil now its wants me to change oil again and it smokes really bad now to much oil or too little
the 1050 holds 57.5 oz slightly less than 2 qts 64 oz. the filler stick is marked. shiould be over the add mark not over the full mark
Jul 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My Cub Cadet oil light was on it read 100 hours
Yes, you overfilled it with oil. Drain the oil and fill to the correct level. If you are not sure how much to put in, add small amounts until the dipstick shows a full reading.
Jun 15, 2009 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
885 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
