SOURCE: toilet running and won't stop.....it
When water goes over into overflow tube then that means 2 things.
The rubber flapper at tank bottom is good and does not need replacement at this point.
That leaves 2 possible problems.
1) The flush valve needs to be adjusted so water turns off sooner.
Flush valve lets water into the tank.
For example if you have a float ball on end of brass rod, just bend the brass rod so the float sits lower in the water.
If you have the 'fluidmaster' then a float rides up and down with water level. There is a metal rod with a metal clip. Squeeze the metal clip and move it downward on the metal rod.
2) If water will not turn off after adjusting flush valve, then replace flush valve.
Local hardware store sells the part and can help with instructions.
You need a crescent wrench or large adjustable pliers.
Plumber can also install the flush valve.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plunbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: I recently tried to install a Peerless Toilet
return it sometimes they dont work on everything or has a flaw that you cant see
SOURCE: My toilet keeps running and won't turn off
try re placing flapper valve located at forward center of tank.
