Won't agitate or spin
I have a GE Profile washing machine (model# wsse4220a0ww). It will not spin or agitate but it will fill up with water and drain just fine. I opened the front panel and check the belt to the motor and it also seems to be just fine. Any ideas? Thanks, Steve
  • scooter906 May 21, 2009
    I have the same issue, and it's not the lid switch. Any other ideas? My basket will take one or two rotations and come to a screeching halt. Smells a little like burning rubber.
    President:
  • 1,136 Answers
Hi, Get a stron magenet and place it on the lidswitch activator located on the cabinet where the lid closes. If you don't have a magenet, remove the front panel again and locate the connector for the lid switch. Use an insulated wire and try jumping the lid switch.
I hope this helps you. Please let me know if I can assist you on any other questions or geting the part.
Vic
Posted on May 20, 2009
Ge profile top load washing machine won't agitate or spin. Fills and drains fine. Tried motor reset (lift lid 6 times). To no avail. Lid switch is magnetic.
make and model information might help. try contacting the factory for guidance if you have those pieces of info.
age might be a factor...... how old is it ?
Mar 24, 2018 | GE Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Washer fills with water and drains but will not agitate or spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 26, 2010 | GE Profile WPRE6100G Top Load Washer
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Washing Machines Logo
213 people viewed this question
Top Washing Machines Experts
