Question about ElectroVoice ND267A Professional Microphone
How you take the top of a EV N/D267a mirophone apart to repair a loose component
Crackle or popping from EV Sx 100+ speaker
test this : Gd bless you
Line noise is feeding in from the AC line. Use an ac line filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 10, 2013 | ElectroVoice Audio Players & Recorders
How do I open up an EV sx100+speaker to fix the diaphram?
I just replaced diaphragms in the tweeters in a pair of EV Sentry 200 speakers. The tweeters had 4 bolts holding them together. One of them was stuck. It's just a matter of gently but firmly twisting it back and forth until it starts coming apart. Make sure you take it apart evenly or it will bind.
Sep 12, 2012 | ElectroVoice . Speaker
Third gear very difficult to engage!!! apart from adjustment of clutch why would this occur/ bike has only done 12,000 year of manufacture 2000.
You should see the manufacturers workshop manager. If worth his salt, he will advise you. It is more than likely a bent or broken part inside the gearbox and they will be most qualified to repair.
May 31, 2010 | 2000 Moto Guzzi California 1100 E.V. -...
Rheem 13PJA42A01 heat Pump,top side freezing how to troubleshoot expanion valve/repair?
expansion valve should make a ticking noise when powered up, if not it will be a faulty ev coil motor or pcb not supplying voltage.
with a set of guages on you will notice the unit will pump itself down if the ev is not operating or there is a blockage.
Dec 20, 2009 | Heating & Cooling
I recently purchased a EV P3000 amp not working.
get all components from (rs components).take fuses down there and there let u know the right ones.mapdata?cxw3pxedhfvx-f8gdwxajgjiuqfsakdckaecygeczw4
Aug 03, 2009 | Audio Players & Recorders
Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Both my EV RE20 Mics have somrthing loose in them
Here's a schematic that displays the assembly of your mics. You should only need a hex tool, jewelers screwdriver, and some patience.
http://archives.telex.com/archives/EV/Microphones/Service%20Manuals/PL20%20&%20RE20%20Service.pdf
Cheers,
NTIMID8
Dec 12, 2008 | ElectroVoice Electro Voice PolarChoice...
Microphone for the first rock band is not working, Xbox 360
If I remember right you have to have one of your controllers on for the mic to work since the mic doesn't have controls on it.
Nov 16, 2008 | MTV Games Rock Band Bundle for Xbox 360
ElectroVoice ND267A Professional Microphone Logo
77 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
