Question about Black & Decker CTO649 Toaster Oven with Convection Cooking
Upper unit The upper unit has quit working
My toaster oven quit working--the led display lights up just fine but no heat. I unplugged/replugged and it worked! for awhile. Then, the same thing and the plug had no effect.
take it in to an appliance repair shop as it may be the elements or thermostat control that is faulty
get a quote as the repair may be more expensive than a replacement unit
Jun 16, 2017 | Toaster Ovens
To replace the upper heating coils(2)
Toaster ovens are inexpensive, may be better to replace the unit, then fix it.
Oct 13, 2013 | Toaster Ovens
Need heating element (upper) for GE168947 toaster oven
You should be able to install a new replacement element or a used element from another GE168947 toaster oven.
Jul 03, 2012 | Toaster Ovens
Black & Decker toaster oven won't work
We've had many of these over the years...they seem to run along just fine, and then, one day, they quit. There is no fuse, but if it's the only thing plugged into that wall outlet, the one thing you might check is the circuit breaker on that line. To be sure, plug a lamp into the socket just to make sure you're getting electricity out of the wall.
Sorry to say, it may be time to purchase a new unit.
Sep 14, 2017 | Applica CTO6301 Toaster Oven
Have delonghi convection oven model A52870B that abruptly quit. symptom of blown fuse. does unit have a fuse?
Hi, if the the toaster already quit, that could be probably the fuse that got busted on your Oven. you can check with any local technician in your area to see on how you can get it changed.
Thank you for using Fixya.
Jul 15, 2011 | DeLonghi Toaster Ovens
Upper heating element is out ... is the element replaceable ?
What is the make and model number of the unit in question. If it is replaceable, I can get you a part to order.
Benjamin
Nov 04, 2010 | Black & Decker Toaster Ovens
Broiler doesn't work: the upper coils do not light up in any sett
try and try to test the broiler..if it does not really work,look for someone who can fix it
Feb 08, 2010 | Euro-Pro EuroPro 6Slice Toaster Oven with...
Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Apr 01, 2009 | Russell Hobbs Toaster Ovens
Sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Black & Decker CTO649 Toaster Oven with Convection Cooking Logo
50 people viewed this question
Top Black & Decker Toaster Ovens Experts
Steve
derbed
Level 1 Expert
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
