Question about Toyota Sewing Machines
Toyota SP100 Bobbin Winding Spindle Won't Turn
Once the bobbin is placed on it, the spindle doesn't seem to be turning and the bobbin will not fill.
5 Suggested Answers
  • 152 Answers
SOURCE: bobbin won't come off the winding spindle
Your bobbin was basically crushed slightly, to remove it simply take the thread off the bobbin and it will come off very easily.
When you wind a bobbin on a Husqvarna and you leave the machine threaded to wind the bobbin through the needle, you must take the thread down below the foot (a metal foot only) before you take the thread up to the bobbin winder. If you take the thread directly from the needle it creates too much tension on the thread and crushes the center of the bobbin so that either you can't get the bobbin off the spindle or in some cases it damages the bobbin completely.
Some threads, the kind that can stretch slightly when pulled, shouldn't be wound through the needle at all. Instead go through the first guilde and then straight down to the little metal "button like" guide and then to the bobbin. It will create much less tension on the thread and wind it much better.
Posted on Oct 12, 2009
Testimonial: "yes,actually that is precisely what I ended up doing, but thank you for the tips as to how to avoid it happening again. It is a great help!!!!"
RichSew
  • 184 Answers
SOURCE: Viking1+ bobbin keeps winding and machine won't sew!
Cathy, you are not getting the ring on in the proper position. If I remember correctly there is a small notch or groove that has to match up on the spindle for ring to go all the way in.
Posted on May 27, 2010
Testimonial: "Thank you so much! It's working great now! Best wishes, Cathy.x"
trial2962
  • 107 Answers
SOURCE: I am unable to fill my bobbin. The motor goes but the bobbin spindle does not turn.
Change thesmall belt which is turning your bobbin.
Posted on Feb 21, 2012
SOURCE: bobbin stuck on bobbin winder spindle
you might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
Posted on Nov 29, 2012
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
I just inherited another Huqvarna (this is a model 630). It was working great until I wound a bobbin on it. After I removed the filled bobbin the machine won't move the needle up and down (but the bobbin...
I do not know the Husqvarna Viking 630. However, I have used the Viking 6690 and it has a similar on-the-side bobbin winding routine. I suspect that you failed to move the bobbin winding mechanism back into the sewing position. Look closely at the area around the bobbin winding spindle. It looks like there is a lever below the spindle. Does this need to be moved or rotated? Double check the steps in the manual and check that you did the opposite steps of preparing to wind the bobbin.
On the 6690, you pull out a knob after removing the bobbin. (You push this piece in and put the bobbin onto the now exposed spindle for winding.)
I hope this helps.
Dec 21, 2014 | Sewing Machines
I cannot get my Brother ES-2410 machine to fill the bobbin. I have followed the instructions but the bobbin spool does not seem to turn. Any advice please?
Grasp the big wheel on the right hand side and pull it out (to the right).
Thread the bobbin and put it on the bobbin spindle on top. Push the bobbin and spindle to the right. Turn on the machine and spin it up. The bobbin spindle should turn and the machine should not sew.
Oct 05, 2014 | Brother Sewing Machines
Singer 362 bobbin
It appears from the manual (see pages 9-10, which are on 11-12 of the pdf version) that it is necessary to disengage the hand wheel (loosen the center knob) with the bobbin winding lever all the way to the left, before putting the bobbin on the winder spindle. Put the bobbin on the spindle, then set the winding lever to the right position to engage the spindle drive. Do not tighten the hand wheel knob until after the bobbin is wound and the lever is moved back the left to permit bobbin removal.
If you are following these directions exactly, or you can't get the hand wheel knob loose, you have a mechanical problem to solve. You may need a stronger hand to loosen the knob, or something in the bobbin winder is bent, out of adjustment, or jammed with foreign material. If you are mechanically inclined, you may want to remove the top cover of the machine for inspection.
Dec 02, 2013 | Sewing Machines
When bobbin in filling, the needle won't disinguage?
slide the bobbin winding spindle. if that doesn't disengage the needle... your machine may need professional servicing.
Sep 01, 2012 | Janome MC 4400 Computerized Sewing Machine
How to remove and fill bobbin
Locate the bobbin access panel to the right of the presser foot. Place thumb tip in the oval hole and pull to the left, (It might also tip up, but I doubt it.) Reach in and lift and grasp the little lever on the bobbin case, pull it out. Remove bobbin from case. Select the thread you want to fill the bobbin with. Place it on the thread spindle. Pull thread trough the small round tension disc on top of the machine and back toward the short spindle on the right top of the machine. If your bobbins have holes.. thread a hole and place the botton on that short spindle. Slide the bobbin and spindle toward the metal "fence". Loosen the hand wheel by turning the center knob counter clock wise. Grasp the little thread on the bobbin and start winding a few revolutions with you holding the thread. Stop and clip that short thread close to the bobbin then continue winding until full.
When the bobbin is full. Return the hand wheel knob to it's original position. Slide the bobbin winder spindle away from the "fence" and remove the bobbin. Place the bobbin in the case with the bobbin facing you... the thread when pulled should rotate the bobbin itself clockwise (VERY Important!) Hold the lever open and replace the bobbin.
For your convenience I have located this PDF for your machine. (be patient, it takes a while to load)
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/38ca989591640b1a852575f30058c8ff/$FILE/Pfaff%20260%20.PDF
Aug 09, 2012 | PfaFF Sewing Machines
What's your problem?
if the bobbin thread is winding around the bobbin winder spindle then
the bobbin is not sitting correctly on the bobbin winder spindle,,
the bobbin (metal or plastic) should lock in on the bobbin winder spindle
& the the thread should be around the bobbin tension guide
Apr 04, 2012 | Sewing Machines
How do I load a bobbin?
There should be a small spindle up on top near the wheel (right hand side).
Start winding the thread on by hand a few wraps to hold it in place and put the bobbin on that small spindle, making sure it is going to wind the proper way. To find out what way it will wind you can first (without the bobbin) push the spindle to the right so that it spins when the wheel turns, turn the wheel by hand for this so you can see which way it is spinning the spindle. Is it clockwise or counterclockwise? Then put your bobbin on and push it to the right so that the wheel will turn the spindle as you press the foot pedal. You should have some sort of tension clip on the top left of your machine, it looks something like the top of a big screw or may be a flat hook. Put the threat under that so that it goes directly from the spool to the bobbin, NOT through the needle. As gradually as possible wind the thread onto the bobbin but not too full, most machines will stop filling it when the bobbin is full. If yours does not, stop filling it when there is still about 1/16 th of an inch room left.
Nov 21, 2009 | White Sewing 1866 Mechanical Sewing...
Winding bobbin- elna
The bobbinwinder spindle is on the top of the machine on the right.
Try to turn the spindle with your fingers. If it is turning easily, good. If not, see below.
Push the spindle to the right and it should turn when the handwheel turns.
If the spindle does not turn properly, remove the two screws that hold the top cover on. DO NOT REMOVE THE SCREW THAT IS ON THE SMALL BLOCK NEXT TO THE BOBBINWINDER SPINDLE.
The top cover will not remove because of the handle. While lifting up the cover, peer under to make sure that there is a small rubber tire on the under side of the bobbinwinder spindle.
If the tire is there, place a small drop of oil on the spindle and turn it until it frees up. Try not to get oil on the tire, it will make it slip. Wipe it off if it gets oily.
Replace the top and retry.
Jul 26, 2009 | Elna 2007 Mechanical Sewing Machine
When I go to wind the bobbin the needle still moves up and down and it will not wind the bobbin but stop beep and flash. The bobbin is as far to the right as it can go but it still is not winding.
Take it to repair shop, getting to the problem requires taking the shell cover off the machine, difficult to do, then fixing the problem might be electronic in nature.
Jun 28, 2009 | Singer 7436 - INGENUITY
Sewing Machines Logo
29 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
