I would not drive it in case the engine died, the symptoms you describe are indicative of possible cylinder head issues.
Get a GOOD garage to visit or have them tow it into their premises to check your vehicle over.
Check your engine idol. It could be that your idol speed is set to low. It should probably run at between 800 and 1000 RPM. If it is not then your idol is to low.
Idle problem like what? too low? too high? If it is too low it could be because your air filter is way too dirty or the throttle body has a bunch of carbon built up in it around the butterfly valve and gets no air at idle. If it is too high you have a vacuum leak. air sucking in from a cracked hose or intake manifold gasket. Check all your vacuum hoses and spray carb cleaner around the intake manifold gasket while the car is running.
check for air leaks on the emission system, if fine, check for the throthle posittioner disconect it, if idles good, replaceit, next go to the idle motor, is next to the throthle body, remove it and clean it with a good carburator cleaner, install it and start the car.
good luck.
the idle screw can be located by following the throttle cable to the carby body, you will find a quarter wheel which the cable hooks into at the bottom you'll see adjustment screw, this will adjust your idle speed.
