Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Samsung RS2545SH freezer cooling problem
The digital reading for the fridge side reads 34 degrees and the freezer side reads 64 degrees.This even after hitting the power freeze button.
  • Randy Orndorff May 23, 2009
    I have already cleaned the coils there is no icy build up and the fan also works.on the display the filter light is on.when I boutgh it the temps read 34degrees on the fridge and 74 on the freezer.Ir sat in my truck fir over 24 hours.we unloaded it it sat for 1-2 hours I plugged it in set the temps to 34 and -4.The next day the temps read 34 degrees for frigde and 48 for the freezer and that is where I'm at today.
  • Randy Orndorff Jun 12, 2010
    Why would the refrigerator side get down to 34 degrees and not the freezer side?Shouldn't they both get to the same temp? If the the freon is leaking and/or the compressor isn't working would the refrigerator side still get down to 34 degrees? Had a "repair" guy come out and replaced the PCB main board and a coil still doesn't help he said the compressor and fan were running.
    Brigadier General:
  • 8,619 Answers
Hi
Try cleaning the condenser coils and also check if there is frost on the back of your refrigerator. Aslo make sure that the fan next to the compressor is running. For more information you can refer the service manual below.
You can view/download the service manual for your refrigerator from this link---
Samsung RS2545SH service manual
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 23, 2009
  • Rylee Smith
    Rylee Smith May 23, 2009
    Then its the freon gas which is leaking from the coils or the compressor has gone bad. You'll need a proffessional to get the compressor and/or freon gas issue fixed as it requires a license to repair the compressor and gas leaks.
    Before proceeding for any repairs i'll suggest you to follow the service manual for your refrigerator and check the control board connections. For that you can view/download the service manual from this link---
    Thanks
    Rylee
RS2545SH. Fridge side is not cooling. Thanks
I have the same problem....anyone have a fix
Oct 18, 2009 | Samsung Refrigerators
Temperature reading incorrect
there are thermistor,sensors and themal fuse by the evaporater on fridge side have to take plastic cover off evap but is prob over frozen and will need defrosting these are quite complicated.
Sep 13, 2009 | Samsung RS2534 Side by Side Refrigerator
How can we install a electronic control panel on
very unlikeley to be the user control panel probably the freezer sensor or freezer fan not operating so no cold air circulating giving a false reading? is it colder at the bottom of the freezer than the top ? that is a dead give away for the fan
Jul 25, 2009 | Samsung RS2630SH Side by Side Refrigerator
Error codes for Samsung Fridge
you need to check the refrigerator defrost sensor connection thats behid the light bulb in the middle of the refrigerator section
May 24, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Dec 01, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerator not cooling
Open the panel in the freezer, and take a hair dryer to the frozen coil.
May 13, 2008 | Refrigerators
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
628 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
