Question about Miller Welding Tools
Lincoln weldanpower won't idle up - Miller Welding Tools
How do i separate the motor from the rest of the unit onan weldanpower 125
Take off the end cover on the generator. There is a bolt that goes thru the shaft that bolts to the engine Once that's out then the remaining bolts on the housing come out to seperate the generator from the engine.
Jun 07, 2014 | Electrical Supplies
2000 Lincoln continental idles at 2100rpm and if I try to drive it it won't shift until it reaches 4000rpm
CHECK FOR THE MODULATOR VACUUM LINE THAT RUNS FROM REAR OF ENGINE DOWN TO TRANS.
** ALSO, LISTEN FOR VACUUM LEAK) RECONNECT AND IDLE SHOULD DROP & CAR SHIFT PROPERLY!
**ALSO, IF YOU HAVE NOT HAD A TRANS FILTER/FLUID CHANGE....DO THAT AS WELL!
Jul 26, 2013 | Cars & Trucks
My Lincoln navigator won't start will turn over but won't start
you either have no spark , check spark plugs, or fuel pump isnt working , dont know the year of your lincoln but it could possibly be a fuse for your fuel pump ..
Feb 17, 2013 | Cars & Trucks
2004 Lincoln aviator goes into gear but won't move
bad transmission maybe. Try going into a lower gear (2 or 1) and giving it a little gas and holding it there. (about 2500 rpm) Hold it there for about 30 seconds.
If it still doesnt move, look under at the side of the transmission where the shifter cable connects and make sure it is moving.
Make sure the brake is on and the wheels are blocked and have a friend shift it back and forth while you look.
Sometimes, the connection pin comes out and you wont shift. .
If it does move right away, head to the transmission shop.
Dec 30, 2012 | 2004 Lincoln Aviator
2005 lincoln ls has 1500rpm idle when started would like to adjust it down
The idle is controlled by the PCM, there
is nothing to adjust,it is all drive by wire
Does it go down to 750 rpm after about one minute
from a cold start ? About 1200 cold-- that is normal
Are you in a hurry-- let the car warn up, it won't run on
O2 Sensors for about 5 min until warm
Make sure your using 5W-20 full syn oil every 4,000
miles at most & change the power steering fluid & trans
on all veh every 3 years-- if you want them to last
I have a 2004 LS V8
Do you have stored codes ?
Have you had other issues lately ?
Is the battery original if so replace it,
that is your problem
Have to get battery from dealers parts counter
as it has a vent for the hose out of trunk
The price is on the web site & is not discounted to
repair shops
I think I paid $119.00 in May but i pay no tax
Oct 20, 2012 | 2005 Lincoln LS
My 1983 mark vi wont stay running
  1. 1983 LINCOLN MARK VI Idle Air Control (IAC) Valve
    www.rockauto.com/catalog/x,carcode,1188323,parttype,6072
    1983 LINCOLN MARK VI Idle Air Control (IAC) Valve - RockAuto.Com, 1983 LINCOLN MARK VI Idle Air Control (IAC) ValveĀ® ... No Parts for This Category ...
Apr 21, 2012 | 1983 Lincoln Mark VI
91 lincoln town car. does not idle for long goes dead
It sounds like a vacuum line off somewhere, does your engine light go on?
Feb 10, 2009 | 1991 Lincoln Town Car
Welding Tools Logo
77 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
