Question about Bionaire Dehumidifiers
How to change the filter - Bionaire Dehumidifiers
Changing the filter on a Frigidaire dehumidifier model no. FFAD5033R10
Hello Paul, thank you for your post!
From my understanding you need help changing the filter on your Frigidaire dehumidifier. I have located a copy of the manual and on page nine it will provide you with proper instructions on how to remove the filter. Best of luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Edison/66129917125en.pdf
Apr 06, 2016 | Frigidaire Dehumidifiers
How do I change the filter on my dehumidifier lad704tdl
The filter on the Frigidaire LAD704TDL is behind the louvered section of the housing above the water bucket. Remove the water bucket by pressing the sides gently to release the bucket from the dehumidifier. Then pull the bucket towards you and use the handle to move it away. Then reach up and pull the filter down. You can wash the filter or replace it with a new one.
For pictures, see the manual: manuals.frigidaire.com/prodinfo_pdf/Edison/66166042enaen.pdf . The filter maintenance is shown on page 8.
I hope this helps.
Mar 09, 2015 | Dehumidifiers
Shows change filter where is it located?
Hello Ann, this is JK. I understand that you are looking for the location of the filter in a dehumidifier. Generally, you will need to remove the bucket to be able to reach under to remove the filter. Please refer to your owner's manual for more detailed care and cleaning instructions. Hope this helps!
Apr 07, 2014 | Frigidaire Dehumidifiers
Water filter on aprilaire model 700 light keeps flashing
You need to reset by turning thermostat dial all the way to test reset. It will reset itself, then go back to your setting.
Mar 05, 2014 | Aprilaire 700 120V Power Fan Humidifier...
Do I have a filter I need to change in my dehumidifier MHDW
i assume you have a humidifier and not a DEhumidifier? putting water in a dehumidifier defeats the purpose. it should remove the water from the air. don't fill the tank on the bottom. empty it. as for the filter, just use a vacuum across the front fins to remove the dust.
May 10, 2012 | Windchaser MDH-W Dehumidifier
How do I change filter
Try this...
http://www.managemylife.com/mmh/lis_pdf/OWNM/L1002544.pdf
Page 11 includes a reference to how to remove the filter.
I hope this helps
Regards
Peter
Mar 08, 2012 | Kenmore 54501 Dehumidifier
Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Hope this helped you. Please let me know. Thanks.
Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
Do i need to change a filter?
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=291198
here is the air filter replacement (or just pull out and clean your self
here is the breakdown for all parts for your unit
i didnt see another filter unless you see one in the back
hope this helps
Apr 05, 2010 | Goldstar DH304 Dehumidifier
What does "CF" mean when flashing on Kenmore dehumidifier?
MOST LIKELY CHANGE FILTER. MAKE SURE YOU HAVE INSTALLED THE CORRECT REPLACEMENT PROPERLY. LOOK IN YOUR OWNERS MANUAL FOR RESET INFORMATION.
Mar 02, 2010 | Dehumidifiers
Dehumidifiers Logo
65 people viewed this question
Top Bionaire Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Bionaire Dehumidifier Expert? Answer questions, earn points and help others
