Question about Frigidaire FGF378AC Gas Kitchen Range
Need clock overlay touch pad can't find compatible part
Looking for clock overlay only for old frigidaire model cfef385jfs4 in white, does anyone know of a compatible part? Don't want to replace whole clock timer, just the touch pad is worn, can't find anywhere
  • kaccettola May 21, 2009
    I need a white overlay, are you able to get one of those?
    President:
  • 1,136 Answers
Hi, I can get you the overlay. It is about 30.00. It is black in color.
Vic
Posted on May 20, 2009
  • Victor
    Victor May 21, 2009
    HI, Could you check the model # again please. I am finding nothing in white. One # or letter could be the difference.
    Vic
Change time on frigidaire microwave no clock button
Hi ssullivan013 - Here are some generics instructions that I found for the model number posted above. Hope the information is helpful.
Suppose you want to enter the correct time of day 12:30 (A.M or P.M.).
1. Touch Clock pad.
2. Enter time 1,2,3,0 and press CLOCK pad again
This is a 12 hour clock. If you attempt to enter an incorrect clock timer, ERROR will appear in the display. Touch the CLEAR/OFF pad and re-enter the time.
Mar 18, 2013 | Frigidaire PLMV169DC Microwave Oven
Getting a F1 code
you have a bad clock assy. if you send the full model number i can look up the part for you,the part number that comes up is 316557115 and it's around 85 dollars,you should also order the overlay part number 316419103 and that's around 25 dollars.go here http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-FEF366EBF/1428/0124111/R0903076/00001?blt=06&prst=&shdMod= and look at part number 20 and 20a,these are the parts you'll need,sometimes you can get lucky and peel the overlay off of the old board and reuse it with a putty knife but if it's beat up looking the part that you push on change it out.also when you call your parts store give them the full model number and the color of the overlay so you get the correct parts,open the bottom draw under the oven door,look on the left or right side of the frame not on the draw and on the frame you'll find a tag with the model and serial numbers,give them the full model number so you get the right parts.good luck and have a great holiday.
Dec 11, 2011 | Frigidaire FEF366 Electric Kitchen Range
My oven..whirlpool model...has F1 in the display window. What does this mean?
F1 error code usually means that either the touch pad or the clock (ERC) is bad. It's simple if your model incorporates both as a single assembly - replace the clock/touch pad, problem's solved. But, when the touch pad is a separate component from the clock, how do you tell which of the two has failed, without having to replace both? Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands.
Solve it with replace electronic oven control (also called EOC or clock).
Hope helps.
May 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
F1 is showing on my oven
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hard to read temp setting on electronic touch pad
replace the clock the display is behind the touch pad .. mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEF369CGSA ramge- replace clock overlay/control labels
Hi Dagmail543
You can only access the old unit by removing it from the back of the panel.Some screws and clips (base at the two sides) The clock is usually secured with screws. - remove old unit replace with new - no peel or scrape usually necessary
Regards
Aug 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F1 error code, beeping
You have either a bad ERC (clock) or a bad touch pad.
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    N
  • OTE: Some models incorporate the touch pad and the clock as one part.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Aug 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Replace clock on range
    there is screw on back of range. remove screw and pull of back cover. that will expose clock. make sure you unplug unit first. don't forget where wires/plugs go
    Jun 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Replace clock timer
    ok bobo lets go....always unplug unit first...pull the range from the wall,,,best if you get behind it if you can,,,now you those 8 phillips head screws around the top back of console..remove that bact console panel...now there 4 screws holding the clock in remove screws but not the wires..let the old board just hang from wires,,your close now ...put new board in there did you get the overlay with the new board ,,no..so take that flim strip overlay of the old one,,ok mount the new clock put back for screws,,,take the old clock timer connection off one by one and put on new clock ,,...you did it,,,just reverse to put together,,,
    Dec 29, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Digital clock replacement
    Easy- take off back of console and you'll see what else needs to be done. Take overlay off old clock to reuse. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
    Nov 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire FGF378AC Gas Kitchen Range Logo
    180 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
