Question about Philips 42PFL5603D/F7 LCD TV
Sky remote code for a Philips 42PFL5603D/10
Just cannot find the sky HD remote code anywhere, can you advise?
SOURCE: PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Posted on Sep 29, 2008
DVIroyce
  • 64 Answers
SOURCE: Is a Philips SB329986 HD enough for Sky HD?
Cant find specs on your Model. If it is HD 720i or 1080i both will work. But then again the Sky box may convert the HD to composit, which makes ordinary old TV sets look fantastic. On a HD set they look even better. don.t worry it will work.
Posted on Nov 08, 2009
Testimonial: "Thank you no need to buy a new tv and am v excited about upgrading now!"
abilenetech
  • 65 Answers
SOURCE: how do i watch movies on a philips 42pfl5603d/f7 from flash drive
the flash drive connection is usually for viewing pictures, but in most cases its used to upgrade the tv
Posted on Nov 18, 2009
SOURCE: I have just changed from sky+ to sky+hd. My TV is
You need to connect sound separately - DVI only supports video and not sound. You'll notice a 3.5mm audio in jack on the back of the Philips. You need to plug your sound output in there.
Posted on Aug 19, 2010
  • 608 Answers
SOURCE: lines going through the display
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you.
1. Have it fixed by a professional $$$$$$$???????
2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. The entire board costs around $250 right nowbecause they are in high demand right now. They can be found at tv-part.com but supplies are limited.
3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shutsoff on its own problem. I'mworking on uploading pictures to help guide people though the process aswell. Let me know if I can do anythingto help. Hope this helps and Good luck. Kaufman605
Posted on Dec 12, 2010
Lg 50pq6000
there is no code stored in the remote control for sky+ rev 4 and 6
for sky+HD remote revision 8 code is 1293
rev 9 and 10 and sky q rev1 code should be 2210
Mar 30, 2014 | Televison & Video
REmote CONTrol Code
0728,0716,0733,0719 are the codes to check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. More than Nine Lakh viewers cannot be wrong.
http://electrohelponline.blogspot.com/
May 06, 2013 | Philips 42PFL5603D/10 TV
Hi, I bought my LCD Philips 42PFL5603D/10 have a problem with it. Turn the TV on any program and after about 20 minutes the TV turns itself off and I can not turn on the remote, turn on the TV button on...
if you have electronic experience - open the back check the power supply for busted/leaking or swollen caps - replace them and i bet your tv comes back on - big problem with the philps/magnavox brands - well a lot of brands actually.
thanks,
michael
Apr 05, 2011 | Philips 42PFL5603D/10 TV
Sky remote codes for television model 42PF9631D/10
Hi
The correct code (or whether there is a code at all) depends on which version of the Sky remote you are using. The version number of the remote can be found on a sticker inside the battery compartment. If you have "RC1600/00" "Rev 4" or "Rev 6" on the sticker, then it's unlikely that it will work with your TV, but please read on as this isn't always true.
If you have a "Rev 8" remote then it's more likely to work with your TV, however, according to Sky, you will need to buy the new "Rev 9" Sky remote:
http://www.thedigiboxshop.com/sky-hd-remotes-sky-hd-remote.html
If buying one, be sure to check the button for the "Rev 9" version ( £0.85).
The actual code for your TV model is: 0718
I suggest you try the above code regardless of which version of Sky remote you have as Sky's information is not always accurate. You can also try these generic codes for Philips TVs:
0584, 0266, 0065, 0749, 1679, 0199, 0679
Again, try these with whichever version of the Sky remote you are using. There is a good chance that one of them will operate the volume and power functions on your TV. If none of the above codes work, then you will probably need to buy a Rev 9 remote.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
I have a toshiba regza hd ready flat screen tv. Need to program the sky remote for it but do not know the model number. Can't find it on the tv anywhere or find the manual! Any ideas on how I could find...
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
Nov 18, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
The tv does not respond to some buttons on the remote but does to others. The ones not working are Power and Channel but Volume and Mute work. New batteries make no difference.It is a Phillips tv with...
There is a way that you can check the remote buttons are working.
Get a mobile phone with a camera on it.
Set the phone to camera mode.
Whilest looking through the mobile. point the the Tv remote at the camera phone and press each button individually. what you will see on your mobile is a light coming from the remote for the buttons that are working. If certain button are not working you will see no light through the camera phone. If this is the case you may need to get a replacement remote.
If you do need to replace the remote this can be quite expensive to buy from the manufactor. So what I would surgest is getting a sky remote off a friend or family member. or even Tesco. argos. It does not matter what the remote is ie Standard, Sky+ or HD remote. (which ever you can get cheaper) The reason behind this is Sky remote have a default code in them to work PHILIPS tv's. When you get this remote if it does not work your telly straight away. What I would then do is remove the battery's from the remote for a minimum of 10 minutes that way it loses the code someone has set it up for and defaults back to Philips Code.
All of the above will sort your Problem out.
Thanks Little Dish Fitter
You owe me a Pint. : )
Sep 24, 2009 | Philips 19PS50S 19" TV
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Sky+ remote codes
hi
i have here some writeups i found during surfing for your sky remote.
Not every TV is included in the code list. In fact, although it was claimed that "95 percent" of TVs could be controlled by the Digibox remote, the true figure is probably "95 percent of last year's models" and the standard remote will NOT control your Video Recorder or any other equipment.
UPDATE October 31, 2006. The latest versions of the remotes are SKY Rev.8 and SKY+ remote are Rev.6 and Sky-HD are Rev.8 (Sky-HD also operates the SKY+ Digibox and contains codes for more recent Plasma and TFT screens). Look at label inside the battery compartment. These remotes contain codes for more recent TV sets and omit codes for TV sets that are now several years old. We do not stock earlier revisions.
seems here that they may have no codes for your tv.
i will just update you if ever i find codes and ill post it here.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 42PFL5603D/F7 LCD TV Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
